what injectors for 06 - Ford Powerstroke Diesel Forum
Old 11-10-2011, 01:57 PM
need to know what is the best injector not looking to go much over stock as i tow 10k time to time
Matt
Old 11-10-2011, 02:09 PM
I Love Workin On Hotrods
Well if you are not going to upgrade your turbo and you tow and you dont have studs, then I would recommend you dont get new injectors at all unless you have a bad one or something. Now if you do have a bad one and just want to replace them all with some upgraded injectors then I recommend you figure out what your goals are for the truck as to whether or not you will want to replace the turbo or not. Lets say you go with a powermax turbo then I would recommend 175cc injectors as you will be able to have a tow tune written so you can tow your 10K load. Hope this helps.
Old 11-10-2011, 02:10 PM
Oops forgot to add that I think for the money Warren's injectors are tough to beat. JMO.
Old 11-10-2011, 02:24 PM
Towing that much weight I recommend staying 155cc max or just Stock. We currently only offer Stock size injectors but are working to be a stocking dealer for Warren.
Old 11-10-2011, 02:52 PM
i have a bad one so 155cc are option just worried about them being rebuilt
Matt
Old 11-10-2011, 02:59 PM
1 injector is $225-$275, 8 155cc injectors is $1500-$3500. Why are you replacing all of them? What's wrong with the one that is bad? Have you tried Rev-X?
Old 11-10-2011, 03:00 PM
yea tried rev x
Old 11-10-2011, 03:23 PM
Without studs and towing 10K, I would be nervous about causing a head gasket or other problem. Another thing with larger sticks is you absolutly need a fuel pressure gauge and it would be smart to get an aftermarket fuel delivery system. Low fuel pressure will kill injectors. I know I am a newbie, but I bet I have read 3 dozen threads on injectors in the past 2 weeks because I am doing the same thing. The difference, I have the mods to support them. I too will be towing.... a 12K goose.... and plan on getting 175cc / 75% nozzles, but not until I have an AirDog II fuel delivery.
Like windrunner said, what are your goals. If your not looking to have the power for smoking some kid in a camaro or mustang, I would stick with stock or 155cc with stock nozzles like Fred says. My .02
Old 11-10-2011, 03:52 PM
its 2 months out of warrenty i plan studs and 155 are about max on injectors id want to go just like to hear what brand as not sure i trust rebuilds
thanks
Matt
Old 11-10-2011, 04:06 PM
thanks
Matt
We carry Industrial Injection, they build from Ford Remans like Full Force.
