airdog /starting problem - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-10-2011, 12:03 PM Thread Starter
I've been having trouble getting my truck to start after it's been sitting. Takes 3 or 4 10-15 second cranks for it to start then it starts real rough with a low idle. I have a new 58v FICM from quick tricks so I'm pretty sure that's not it. I realized today that my Airdog is leaking between the pump and the plate. Sounds like it's sucking air when the pump first starts then starts leaking fuel. Then continues to leak even after the truck is shut off. Could this be causing my starting problems? Thinking that it's bleading off pressure and loosing it's prime.
White 2008 F350 Lariat Crew Cab 4x4
Stock wheels, tires and height
Sinister EGR delete with intake elbow
Sinister Intercooler Pipe
Sinister downpipe back exhaust
aFe Cold Air Intake
H&S Mini Max
Gearhead Automotive Tuned
cudaguy is offline
post #2 of 10 Old 11-10-2011, 01:05 PM
rdunagan's Avatar
i doubt it. could be but even at that there would still be fuel in the rails to start the truck atleast. sounds like a bad gasket on the pump which you can call airdog and they can get you one pretty quickly. not sure what could cause it need more info
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #3 of 10 Old 11-10-2011, 02:11 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Yea contact Airdog ASAP.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 10 Old 11-10-2011, 02:26 PM
Fred@PMM's Avatar
Contact Airdog, definitely wouldn't be the first time we have seen a similar issue...
Performance Machine & MFG.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
Fred@PMM is offline
post #5 of 10 Old 11-11-2011, 04:42 AM Thread Starter
I called Airdog, they said the pump shaft seal was bad. I have a new pump on the way. If that doesn't solve the problem I guess I will have to put it in the shop. Very hard to start and when it does it chugs at a very low idle until it finally catches. Sometimes it wont start without me holding the accelerator to the floor.
aFe Cold Air Intake
H&S Mini Max
cudaguy is offline
post #6 of 10 Old 11-11-2011, 06:54 AM
rdunagan's Avatar
i had a buddy of mines truck do that once couldnt figure it out. turned out to be a bad regulator by the fuel bowl so maybe that is your problem and by that i mean the airdog
rdunagan is offline
post #7 of 10 Old 11-18-2011, 10:31 AM Thread Starter
Put the new pump on and it's good as gold. Starts right up. Thanks for chiming in guys!
aFe Cold Air Intake
H&S Mini Max
cudaguy is offline
post #8 of 10 Old 11-18-2011, 12:36 PM
BACKYARDIGAN
Quoted: 4 Post(s)
That is GREAT man and it sounds like Airdog, really came through for you. Did they require you to send your pump in first? It doesnt sound like they did.
Nate
post #9 of 10 Old 11-19-2011, 04:21 AM Thread Starter
Kinda got the shaft on that one. They say I didn't get my warranty card to them in time so they didn't cover it. $165 but they got it to me quick. The new pump is registered. Live and learn!
aFe Cold Air Intake
H&S Mini Max
cudaguy is offline
post #10 of 10 Old 11-19-2011, 04:29 AM
BACKYARDIGAN
Quoted: 4 Post(s)
See that is the stuff that bothers me. I am convinced that the airdog is probably the overall best way to go as far as an aftermarket pump goes but it just seems that too many folks get stuck somewhere and yea they have a "lifetime warranty" that IMO is a POS. Usually stuff that is warrantied for life very rarely fails. JMO. Eitherway glad to hear that the new pump is working great for you now and hopefully it keeps up.
Nate
