center will not fit on 04 2wd with 07 KR wheels
I recently put some 20" king ranch wheels ( I think they are off of a 07) on my 04 2wd and i wanted to make sure everything was right before i paint the tan part white. The center cap bottoms out on the hub of the rear axle and the dust cap on the front. I could probably trim the inside of the cap for the front but there is still aways to go to make the rear fit. I did buy some cheap replacment caps for a 99-04 off of ebay but they are junk and will probably not stay on while driving and it doesnt look as good as the round caps. I would like to run the round cap that belongs with that style wheel. Has anyone else run into this problem?
not that i know of but ive got the KR caps for sale if you want em
Sorry. I posted it to the wrong section. I reposted it to a diffrent section. Please delete this one
If i figure out how to make the caps work i might see if i could buy the rear two from you. I have one set of front and rears already but i will need the 2 more full caps
The backspacing is different on the 05-07 than the 99-04. I had the same problem on my 03 with 07 20" wheels. It wasn't a problem on the front because I used wheel spacers that brought it out enough to work. On the rear I just used the original cover. Your only option to use the new caps is to get wheel spacers. Or just use caps from your 04.
There is nothing wrong with the wheels, its the difference in spacing, just use your existing centers and or buy a set off ebay for an 99-04 truck.
