ELC ?? i have read alot and confused on what kind to buy?? - Ford Powerstroke Diesel Forum
Old 11-07-2011, 01:13 PM
i going to finally do my egr delete and going to flush system and put some ELC in i know to run Cat EC-1 rated ELC but is there different brands ??
i confused reading on the forum what brand to get
can i order it from my local napa i know it has to say ec-1 , and do i need to buy pre mixed or straight ?? or dose it only come one way
thanks
Old 11-07-2011, 01:32 PM
Any brand that says it is Cat EC-1 Rated will do. You need 4 gallons of concentrated not the 50/50 premixed stuff. Napa sells Zerex ELC under part# ZXED1. If it isn't on the self have them order you some.
There are only about 974,361,598 threads with this exact same information.
Old 11-07-2011, 01:48 PM
Slacker
Feedback Score: 4 reviews
Have you counted them all?
Old 11-07-2011, 01:51 PM
I have the links to every one saved for reference in case I forget.
Old 11-07-2011, 03:25 PM
alright thanks i just wanted to make sure there was not just one brand that should be used ill go to napa tom. thanks
Old 11-07-2011, 03:28 PM
ok so get concentrated, i dont mix it at all or mix it my self ? i know that you mix the gold yourself i just want to make sure with the cat ec-1 sounds like a dumb question but i just want to be sure
Old 11-07-2011, 03:42 PM
Feedback Score: 3 reviews
Here ya go, read this.
Flushing and Cleaning the 6.0
Old 11-07-2011, 05:09 PM
lmao
Old 11-07-2011, 05:44 PM
Pooh's link is good.
But the idea with concentrate is that when you flush the system over and over with distilled water, you finally drain it the last time, and then add HALF the systems capacity in concentrate, which is 4 gals since the system is 8gals as a whole. Then if you top it off with distilled water, you end up with 50/50.
Old 11-08-2011, 09:56 AM
Just bought a gallon of the Zerex ELC Cat-1 rated concentrate at Napa for $17.99.
