EGR Delete CEL question - Ford Powerstroke Diesel Forum
Old 11-06-2011, 12:51 PM
Ok everyone, I don't want to be the guy that asks the question thats been answered a hundred times but I've searched high and low and read post after post and cant find it... Maybe I'm just blind
My 06 6.0 finally had the EGR crap out. New valve is $200, Alligator performance has a delete kit for $270. So here is the question. I know I need a tuner to turn off the CEL after a delete, but if I don't, would it cause a problem? Is the truck going to run right if I clear the code before install? Could I get away with cruising around with my CEL on for a few weeks so I can save up $ for the tuner I want?
I can't afford a tuner and a delete kit at the same time!
Thanks in advance for any help!!
Old 11-06-2011, 12:54 PM
My truck seems to sun fine with the Cel on.....but I am not sure about newer strategies.
Sent from my Desire HD using AutoGuide App
Old 11-06-2011, 01:04 PM
If anyone know anything about this alligator performance kit theyd like to share I'd appreciate that too. It was in a issue of diesel power so I assumes it must be fairly well... right???
Old 11-06-2011, 02:09 PM
Feedback Score: 3 reviews
Alot of guys have been talking good about the Dicad Solutions EGR delete. $150
http://egr-delete-kit.com/products/4...elete-kit.aspx
Old 11-06-2011, 02:54 PM
Awesome, Thank you. Ill probably go with that one..
One last question... Leave the valve in and plugged in or remove it and block it off? Ive seen a lot of answers that go either way and cant figure out what anyone says is the best option!!
Old 11-06-2011, 03:17 PM
I just installed the dicad delete, good kit great price, And it was apiece of cake to install.Why spend the extra money unless you want the extra bling.
Old 11-06-2011, 03:26 PM
Leave the valve plugged in.
Old 11-06-2011, 04:25 PM
Yes sir, like already mentioned, keep the valve plugged in electrically.
Old 11-06-2011, 04:29 PM
Yes, some people with newer strategies have reported having engine fan issues when they unplugged the valve.
Old 11-06-2011, 05:00 PM
Feedback Score: 7 reviews
I always leave the valve in whenever I do an EGR delete-Don't see the need to remove it, and it keeps the wiring harness from getting corroded and hanging. The only code you'll get is EGR flow insufficient if you leave the valve in and plugged in, rather than a plethora if you remove it.
