Air Dog Raptor pump question - Ford Powerstroke Diesel Forum
Old 11-02-2011, 10:55 AM
Send a message via AIM to lifted 350
Hey guy's I was wondering if i could take my stock lift pump out and put in filters could I use my Raptor pump as my new lift pump or does it not have enough pressure? It's the 150 version so its the bigger pump, if anyone could help I would appreciate it thank's!
Old 11-02-2011, 11:08 AM
I Love Workin On Hotrods
No I dont think that pump will work as it is only rated at flowing 150gph at 10psi (at least that is what it comes preset at). I believe the purpose of this pump is to be used to feed the stock or another pump to remove the strain on the higher pressure pump. My suggestion would be, if you want to replace the stock pump and want to use this pump, you will need a dahl 150 water separator/filter as well as say an Aeromotive A1000 marine fuel pump. JMO but eiter way i am reasonably assured it wont replace the stock fuel pump. Hope this helps.
Old 11-02-2011, 11:10 AM
I'd say tank--filters--Raptor--motor....
Check your model below. Only one is a full replacement version.
Ford – AirDog Installation Manuals for Diesel Engine Products
