Insight onTurbo Upgrade - Ford Powerstroke Diesel Forum
Old 11-02-2011, 09:33 AM
Looking to upgrade the turbo and injectors on the old 6.0.
I thought about going with a BW S372 and 190 injectors along with some supporting mods. (Studs, upgraded tunes, etc.)
What's you guys thoughts on this? Also would a S372 T4 work/ mount on a 6.0?
Thanks
Old 11-02-2011, 09:45 AM
I Love Workin On Hotrods
What do you use your truck for?? And what are your goals for the truck??
Old 11-02-2011, 10:11 AM
It's a daily driver. I do tow from time to time, any where from 2k to 8k. Just looking to get 500-600hp. Just for fun basically, something different than a Powermax or Aurora.
Old 11-02-2011, 10:13 AM
Thanks
No, you will want a s364 t3 at the most.
Old 11-02-2011, 10:25 AM
and in fact I would probably just do a s362 with a t3. That will put over 500 hp and you could probably still tow.
Old 11-02-2011, 10:27 AM
Thanks Matt. Thats good to know. I like what you did to Brandon's truck. Good stuff!
Do you have any other suggestions on what should be added to the 6.0?
Old 11-02-2011, 10:47 AM
Fuel pump, wouldnt hurt to add a regulated return.
Old 11-02-2011, 12:28 PM
Thanks for the info guys.
Old 11-20-2011, 11:33 PM
how does this compare to the powermax? better or worse?
Old 11-21-2011, 03:57 AM
A s364 with 190s and 100% nozzles would blow the doors off a truck with the same setup but with a powermax. The spool up time would be a little slower but it would flow SO much more air up top. I would think that with the right tuning you should be able to hit 550Hp.
