Fuel pressure sensor - Ford Powerstroke Diesel Forum
post #1 of 37 Old 11-01-2011, 06:05 PM Thread Starter
Beef52751's Avatar
i need to move the fuel pressure sensor for my gauge from the test port. Its rubbing the upper radiator hose. What do i need to do it??? what size line etc. and where should i move it to??
Thanks for the help
Beef
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
post #2 of 37 Old 11-01-2011, 06:09 PM
pizza pig's Avatar
Driven diesel makes an adapter that brings the sensor to the side of the engine compartment where its free of vibration and away from the rad hose
pizza pig is offline
post #3 of 37 Old 11-01-2011, 06:47 PM Thread Starter
Beef52751's Avatar
6.0L Fuel Pressure Adapter
Will this work with my glowshift gauges???
Thanks
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
post #4 of 37 Old 11-02-2011, 07:04 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Yep. I have that exact part and it works GREAT. It is a must IMO.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 37 Old 01-08-2012, 05:40 PM
kafleming19's Avatar
Quoted: 767 Post(s)
Not to bum you out about spending $50 or if you are planning on buying this "adapter" but I just spent $1.41 and made it work without it touching anything. I bought a 1/8th pipe ABP street elbow.
Here are some pictures.
Here is what it looks like without the elbow.
Here is the $1.41 elbow.
Here are the pictures of it installed.
Kily AKA Lt. Axe
kafleming19 is offline
post #6 of 37 Old 01-08-2012, 07:38 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yep, and what is all this worry about vibration. My motor is a smooth as can be. Running the sensor right off the test port is no problem at all.
RIP Mitch
the Org crew
PGreenSVT is offline
post #7 of 37 Old 01-08-2012, 10:08 PM
local851ff's Avatar
Where do I find that pressure sending unit?? Thanks
2008 F350 CC SRW
local851ff is offline
post #8 of 37 Old 01-08-2012, 10:40 PM
PGreenSVT's Avatar
Whoever makes your gauge will have the sender to match.
RIP Mitch
the Org crew
post #9 of 37 Old 01-09-2012, 06:27 AM
Term3's Avatar
I also have my sensor right off the test port for three years now with no issues.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 37 Old 01-09-2012, 01:00 PM
AKHILF574's Avatar
Have had mine right off the test port for over a year and hasnt had a hiccup
2003 F-250 6.0 FX4 lariat, sct with srl++,swamps ficm, Air dog II 165,ARP headstuds,4" straight pipe, airaid intake,4 gauge A piller with prosport gauges,boost,egts,tranny, fuel pressure, 4200 pioneer double din, 4 kicker L7's 12's behind the rear seat, kicker zx2500.1,Fuel hostage all black 22x11's with toyo mt's 37x13.5, 5% tint all the way around
Sold:early 1999 F-250 lariat with most of the fun stuff
AKHILF574 is offline
