Airdog II/Fuel Bowl Delete
Correct me if I am wrong but if you have a Airdog II and the OEM fuel bowl and FPR then your fuel is still being regulated by the FPR and not the regulator on the airdog, correct? Is there a way to delete the fuel bowl and OEM FPR so that the airdog is controlling everything?
Yes, All you would need is to pull the lines off of the front of the heads and disconnect them from the filter bowl. Also remove the fuel supply and return lines that are connected to the filter bowl and remove the lines from the fuel pump. Then run a new supply line with a y that splits to go to the head, then on the back of the motor connect a line to each head and run those into a y and have the single line from that y go back to the tank. Fuel filter bowl is now gone.
Supply from ADII to a Y to the head port banjos. Block off the front of the ADII loop hardline that goes to the fuel bowl. This would allow you to take the fuel bowl out of the engine bay altogether as I have done. If you just want to eliminate the oem FPR from the picture so you can just have the ADII FPR regulate the system the simplest way is to take a coke can and cut yourself a disk the size of the return line fitting on the factory FPR. Put that disk in the return line and reattach the return line to to FPR. That's it. No more oem FPR function. |
I know that it is an unregulated return at the motor with what I described but was I thinking he could rely on the FPR on the Airdog for controlling the fuel pressure. |
Oh yea duh. My bad. I get it now. Yes he would have to dead head the fuel at the heads.
yes you can.. i blocked the return line on mine and removed the stock filter along with the little poppet thingy...
![]() Sent from my iPhone using Autoguide |
You people are brave taking off all the factory stuff if you are just running an airdog 2 I have to have my back up plan my pumps only last a month if I am lucky then I pull over and reconnect the factory stuff and it will maintain pressure cruising to get me home
