Help with SCT Touch Screen Extreme
i was wondering what the important temps and pressures i should keep an eye on when i run this?!?! And also how accurate are the gages on the Extreme?? good enough to just use the extreme??? i put the extreme on my 2005 f250 and holy sh#t!!! i have no problem gettin 37x13.5x20 tires around like it is nothing!!! now i dont know what to expect after i get the heads studded and do a EGR delete and put in the EGT temp probe installed!!!!!! it all should be comepleted buy friday can not wait!!!!!! just unreal power WOW!! thanks for any info!!!
Your biggest temps you need to monitor are your EOT and ECT... IDK if that monitor can do it, but if it can, those are the biggest... If your deleting your EGR, you shouldn't have to big of a problem with it.. but its still good to monitor them.
I have the same tuner and all I use it for is EGT's. You really need a fuel pressure gauge for this truck, especially now that you are running tunes on it. I installed mine in the flip down tray to the right of the steering wheel. I didn't want it to get stolen. The only time I power it up is when I am towing or playing.
yes that screen will monitor ect and eot. you need to monitor those! also you need to monitor egt's as well if you are tuned
thanks for the info that helped!!
