rite now iv got turbo back 4" straight pipe, k&n, aem water methanol, sct programmer, boost builder. iv got arp head studs to put on then send my programmer away for looney wild. ill order injectors as soon as i know what ones to get then get the garret powermax turbo.
Without doing anything? Maybe 155's. Maybe. I would atleast suggest a banjo upgrade with blue fuel pressure spring if not a full RR kit and/or Airdog. I know I'm not going to drop the coin for new injectors and not do a new fuel pump as well such as an Airdog. 155s will get you about 480Hp with a powermax turbo. 175s 500+ HP with a PM, and 190s 525-550hp with a PM.
first off take the boost fooler off. no need for it as tuning will take care of it and more boost doesnt always equal power. on a stock system ive seen 155's live a long time without any problems. if you want to go larger than that your gonna need some type of fuel system upgrade. which you should do the blue spring anyways and while your there might as well do the 6.4 bolts. that right there is like 70 bucks to do if you dont have to buy the regulator housing as well. then just put an airdog on and you could prob do 190's with 75% nozzles but i wouldnt go much past that without a RR.
50's with the right nozzle. that will put you right about 450-475 if you have the right supporting mods. 175's are around 75hp and 190's are around 90-100 depending on the nozzle
yes you could switch nozzles on stock injectors but wont see to much of a benefit. shoot me a pm i can get you prices on injectors from warren diesel or anything else you need
I have only really heard of Maryland Performance Diesel making a 165. I could be wrong though. Where are those fittings and banjos from too? Wonder where they got them from?
i got new fuel lines with the kit and elbows too, gets more fuel to the injectors, less strain on the pump id assume
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
