should i be worried ?? - Ford Powerstroke Diesel Forum
Old 10-24-2011, 08:43 PM
i have a 2005 f250, with 47000 on it brand with a new egr cooler. i want to get and air intake, exhaust, and a programmer. i use it as a every day truck and tow a 24 foot trailer with it about once a week. if i make these up grades is thing gonna blow up in 50,000 miles ?
Old 10-24-2011, 08:56 PM
You don't need an aftermarket intake on these. Do an exhaust and get an SCT X3 or SF3 and get it custom tuned. Biggest thing being able to monitor your engine data and temps, so get gauges. There's a ton of info on here about all that stuff. Go and do a little bit of research. I would delete the EGR before tuning as well.
Old 10-24-2011, 09:04 PM
agree with above....
i would go with this tuner setup:SCT X3 Custom Innovative Diesel Tuning/ Edge CTS combo
and this exhaust MBRP Performance Series Aluminized Turbo Back - Single Exhaust S6212PLM (No Muffler)
Old 10-25-2011, 07:04 AM
Feedback Score: 3 reviews
Get a monitor first, you need to check the health of the motor, prior to spending money on the fun stuff. Fix the issues, then start add in the performance, if you choose to ignore the issues, you'll be sorry!!
Here is some reading material.
Things to consider about owning a 6.0L
Old 10-25-2011, 08:57 AM
I Love Workin On Hotrods
Old 10-25-2011, 09:13 AM
is that a 4 inch exhaust ?
Old 10-25-2011, 09:43 AM
Well, Here's the deal.. you say its got 47k miles..and a brand new EGR cooler... Meaning the Egr cooler has failed... Did the dealer do the work on replacing the EGR cooler?? Do you know if the Oil Cooler Was replaced at the same time??
If the Oil Cooler was not replaced, your going to have the same problem not too long down the line, because the oil cooler is the Root of the problems...
Before you spend money on exhaust and a tune.. I would definitely buy a Edge Insight, CTS or CS your choice on if you want to spend the extra $100 for the touch screen.. I did, and i love it...
Once you can monitor your Delta's... which im going to assume are going to be +15 because of your oil cooler possibly not being replaced... then you can go from there... If you've got a reasonable delta.. Then go for the exhaust, then the tune In that order IMO... You don't need Intake's on these trucks... but to each his own.. I have an Airraid on my truck, and I love it.. I like the sound of the intakes...
But to Answer your Question of the title.. Should you be worried:: My Answer, Would be Yes, you should be worried, until you find out if your Oil cooler was replaced...and what your delta is after a monitoring system is installed.
Old 10-25-2011, 10:08 AM
Unapologetically American
Feedback Score: 4 reviews
The oil cooler should have been replace too, if not, your new EGR cooler is not destined to be in this world long. And don't do this anymore with your truck white smoke at 6000 rpm in park.
Old 10-25-2011, 10:16 AM
Wow, I can't believe I missed that over there..
My truck barely gets above 4k when its WOT in Drive.. Your right foot is what you should be worried about...
Old 10-25-2011, 11:04 AM
they did replace the oil cooler to. your truck looks great man thanks for the help
