adrenaine hpop ?? - Ford Powerstroke Diesel Forum
Old 10-23-2011, 01:28 PM
adrenaine hpop ??
How many of you'll have installed one of these and did your truck run better ? I am thinking about putting in anew hpop this winter . thanks...
Old 10-23-2011, 02:12 PM
I Love Workin On Hotrods
I know I want to get one when they come out with one for the 05-07 models if for no other reason than they are designed to be WAY more reliable.
Old 10-23-2011, 02:33 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
reliability is the only reason I got one in my 7.3. But it also made it so much better
Old 10-23-2011, 04:13 PM
Yes more then anything reliabilty is what I an after. Which one I see they have 2 listed one as a stock replacement the other looks more for performance.
Old 10-23-2011, 04:16 PM
What did you notice, better mpgs etc....? I plan on getting one just think I would feel better having one it not worrying about it failing.
Old 10-23-2011, 05:10 PM
Powerstroke Techie
Feedback Score: 3 reviews
how much more reliable do you want than an 05+ pump? they rarely fail compared to the swash plate pump
Old 10-23-2011, 06:50 PM
Well I just had my HPOP fail on me when I was restoring from my head stud install. I had buttoned everything back up and cranked the vehicle until it started. I only let it idle for a few minutes and had to shut it down due to an oil leak on my oil cooler setup and when I went to restart the truck it never restarted. I bought a new HPOP and have been good to go since, about 600 miles so far.
Old 10-23-2011, 06:52 PM
Powerstroke Techie
sure it wasn't just the STC fitting on the pump? the new pumps come with a revised branch tube connector. the original connector can seperate completely causing a near total loss of high oil pressure
Old 10-23-2011, 06:54 PM
Yes, I had replaced the STC fitting on my pump last fall when I did my egr delete and oil cooler delete. I have to say it was very confusing. Now lets not hijack this thread any more than we already have.
Old 10-25-2011, 06:22 PM
I spoke with Bill from Diesel site about the adrenaline and he said they worked great ,seem to make the trucks smoother and also the standard pump was good for 190 injectors.
