5.38 Gears - Ford Powerstroke Diesel Forum
Old 10-19-2011, 02:33 PM
5.38 Gears
i am going to change gears. i am going to run a 44 or a 54 inch tire.. i am looking for 5.38 gear set..
anyone know of a good place to get gears?? i need websites por favor!!
Old 10-19-2011, 02:48 PM
Randy's Ring and Pinion is where I've ordered several gear sets from. Great service! Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services.
Old 10-19-2011, 03:05 PM
Randy's is great! Top notch customer service as well!
Edit: They will probably ask what you plan on doing with the truck. When you get up in that 5.38 range, the pinion head gets real small. They're not known to hold up to real abuse in a Sterling.
Old 10-19-2011, 03:12 PM
I Love Workin On Hotrods
Yea you would probably be better off with 4.88s or actually what I would recommend is having a set of dana 80s built if you want to go with 5.38s if you plan on much abuse. JMO.
Old 10-19-2011, 05:46 PM
i dont plan on abusing it .. i am gonna run micehlen xl's 43's.. pavement only.. i am building a mud truck in the back yard right now
Old 10-19-2011, 09:59 PM
if you are going 43's go with 4:88's I do not think you can legally run 53's on the road
