fuel pump - Ford Powerstroke Diesel Forum
Old 10-14-2011, 06:27 PM
fuel pump
seriously is there a fuel pump that isn't having of issues it seems every option has a ton of people having issues the stock fuel pump has only been in for two years and its a turd now. what is the best solution for fuel pump choice
Old 10-14-2011, 06:40 PM
Aeromotive a1000
i'd make sure that you make a custom fuel filter setup as well (baldwin fuel and water separator)
Old 10-14-2011, 06:43 PM
I Love Workin On Hotrods
Yea man I totally hear you. It sounds like from everything I've read, the Airdog II with a sump seems to statisically have the best success. Other than that it is a crap shoot. My stock one seems to be holding pretty good with my RR kit on it.
Old 10-14-2011, 06:46 PM
Originally Posted by pizza pig View Post
Aeromotive a1000
In all honesty, Aeromotive is a GREAT brand of fuel pump. Cant say how they are in the diesel world but they are the best IMO in the gasoline race world. I just wouldnt know how to plumb it with the right filter/water separator.
Old 10-14-2011, 06:52 PM
another system to dig into and really figure out it seems, kind of like building your own oil cooler system, nothing is simple anymore
Old 10-14-2011, 06:56 PM
i know of a handful people running big sticks with an a1000 with Zero issues holding 70psi... I think the airdogs and fass are hit or miss and its enough to steer me away. One thing i dont mind is a challenge, if you're all for the bolt on installation the airdog is a great option.
When I do my fuel system ill be adding a sump running all new fuel lines through a 2 micron filter and water separator to an a1000, and directly feeding the heads with a regulated return on the backside and a new return line, completely doing away with anything factory.
Old 10-14-2011, 09:26 PM
Yea screw oem!!!! GO Aftermarket!!!!!
Old 10-14-2011, 09:27 PM
In all seriousness, I agree with all that has been said above and I want to look into the A1000 setup as well
Old 10-15-2011, 08:54 AM
I have several friends running Airdog & Airdog II on Dodges, Chevys and many Fords with no issues. I think the AirdogII is the best out of the box solution, now parting it together you might get a better option, but allot more coin. So it depends on how much you want tot shell out.
Old 10-15-2011, 10:20 AM
honestly building your own wont be that much more expensive. An Airdog II is $660 + the sump, sure its bolt on but like I said if you dont mind assembling things over the weekend building your own is more satisfying.
You may not even spend as much as an airdog if you play your cards right. I have my parts list all laid out and when i make the plunge it runs out to just south of $600 minus the sump
Thats for enough stainless braided line from tank and all the way back to the tank, all parker fittings, baldwin filter heads and filters, a1000 etc. no brainer if you ask me
