Next step in my build?
Ok guys, i'm trying to decide what I want to do to the 6.0 next. So far i've done studs, gaskets, cooler, EGR delete, '03 turbo. Typical "solution" upgrades. I'm also running Xtreme Street from Innovative. I'm getting the itch for more power!
Lemme hear your suggestions! Thanks! Jeremy |
Might want to re-gear first, but then...
Fuel system, injectors, turbo, and tranny in that order. |
I have another thread right now about re-gearing. I'm getting close to talking myself into it. Nothing too drastic. Probably 4.30's.
What would you suggest fuel system wise? This is my daily driver right now. What would 190's and a Powermax be like compared to what I have now? Jeremy |
4:30 gears sound good for 37's.
If you want to do it as cheap as possible I'd go with an airdog 2, might want to look at upgraded banjo bolts too. You can regulate fuel pressure right at the pump on the airdog. Don't know if you'd need to mess with anything like fuel springs, etc on the secondary fuel filter housing... My system is different. I have the original airdog and an ITP reg. return. Also get an in cab fuel pressure gauge if you don't have one yet. I should have put this in my last post. Very important if you have large injectors. With a set of 190's and a powermax you're probably looking at an honest 100 rwhp bump from where you're at now. |
Wow 100HP on top of what I have now would be great! You install your Airdog yourself? Pretty simple? Thanks for the help man!
How much power are you looking to make? I would regear to either 4.30's if its mainly a DD/Off Road truck, and 4.56 - 4.88 if you tow with it.
155cc Injectors, stock fuel, and your '03 turbo will put you around 475HP. 175cc Injectors, aftermarket pump, and the '03 turbo will put you just over 500HP, a little more if you switch to a Powermax Turbo. This would be the limit I'd run if you tow, and the 175's will need to be tuned down on the tow file. Also this would be the limit I'd build if a new/rebuilt transmission isn't in your future plans. For 190cc Injectors, and aftermarket pump will tax the stock turbo and the transmission. I'd definitely step up to the Powermax at this power level, and be ready to build the transmission. This set up will put you around 550HP, and is pretty reliable. If you are looking for more power than that, you're looking at more cash shelled out in supporting mods. |
I tow very little. Occasional boat, load of ATV's, bobcat, etc. Not even once a month. So I'm fairly certain I'm going to stick with 4.30's.
Powerwise, honestly I would like ~500. I don't want more than that because like you said I want it reliable. I've been told that a stock truck with the Xtreme Street tune alone can put down a solid 400HP. How accurate is that? If that's true and that's what I have now, 500HP will be plenty! Jeremy |
Just my 2 cent though. If you adjust the revs/mile the the truck still drives great. If you did tow a bunch though then I'd gear it. |
Jeremy |
