Can someone please help me - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-04-2011, 09:12 AM Thread Starter
I have a 03 f350 6 liter and i don't know what an intake elbow does exactly. I just ordered a stage 2 75-81022
aFe Power Magnum FORCE Intake System; Stage 2 Si Pro GUARD 7; 75-81022. This is the one everyone says to go with but i don't understand this afe intake elbow. There are 2 different ones and what do they do. I i notice a difference in power
Mods done Arp studs, egr delete, sct live wire with extreme race tune by eric. 4 inch exhaust, aftermarket turbo, 190 cc injectors, 8 inch lift on 38 inch rubber,new high pressure oil pump, all new stand pipes, icp sensor, ipr vavle. I just changes all this stuff when i did the black oxidized gaskets. truck only has 90,000 on it
bedrockbobcat is offline
post #2 of 8 Old 10-04-2011, 09:54 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Not knowing anything about your truck or what other mods are done I will tell you that there is NO POWER GAIN to be had here. The OEM filter provides the best filtration and works just fine up until about 500 hp. I suggest you spend your money on a good monitoring system like an Edge Insight CS or CTS first. Much better use of the funds.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 8 Old 10-04-2011, 09:55 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
It won't really do anything from what I've been told. However, it IS already pre-drilled for adding nitrous, should you have been planning to go that route. It also claims to breathe some % more air, more efficiently... I don't know about that - but if anything, it looks fancy under your hood. It is a bigger intake manifold, but I don't think it actually does anything with a mostly stock setup.
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #4 of 8 Old 10-04-2011, 10:01 AM Thread Starter
Sorry the trucks not stock, Arp studs, egr delete, sct live wire with extreme race tune by eric. 4 inch exhaust, aftermarket turbo, 190 cc injectors
post #5 of 8 Old 10-04-2011, 12:23 PM
Real Men of Genius
Quoted: 10 Post(s)
Do you have a stock intercooler? If so, then the Banks intercooler system with their "Ram Air" thing might be a better buy, because it comes with bigger intercooler piping, it should definitely flow more air.
post #6 of 8 Old 10-04-2011, 12:29 PM
Powerstroke Techie
Lilpooh's Avatar
Even with your mods, the real restriction is in the intake manifold and head ports. The CFM+ intake claims more CFM flow, but what good is that air flow if the intake manifold and heads are restricting the air flow.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 8 Old 10-04-2011, 08:28 PM
PGreenSVT's Avatar
Rich is right here. The elbow isn't the restriction and getting a better flowing one won't get any more air into the cylinder. A gogo intake would make a much bigger difference.
RIP Mitch
the Org crew
post #8 of 8 Old 10-05-2011, 01:17 AM
kdogg85's Avatar
Yep. But for a grand off amazon, the banks technicooler with elbow is a nice addition.
As stated, the heads and intake manifold are the big restriction.
unless you are going for monster power gains (550+) Just leave it be and enjoy what you have.
What aftermarket turbo? maybe a 64mm non vgt?
kdogg85 is offline
