EGR delete???? - Ford Powerstroke Diesel Forum
Old 10-02-2011, 04:40 PM
EGR delete????
How hard is it to do it? i can do it with the cab still on? what kit is best?
Thanks.
Brad
Old 10-02-2011, 04:54 PM
information regurgitator
Thanks.
Brad
Not very hard
Yes, the cab stays on, it isn't anything like head gaskets
Pick one. They are basically all the same. Don't be the guy dropping 280 bucks on a delete when a 180 kit will do. What is your definition of "BEST?"
I went with the cheapest one I could find, right off e-bay. Look for a seller by the name of dicad-solutions. It will run you about $150 or so. That is the kit I installed on my truck and have had no unexpected problems. The one thing I will say is that the kit has recently been coming with a "second rate" length of hose. If you are willing to spend about 2 dollars at an autoparts store to get a quality heater core hose (less than 1 foot of it) you shouldn't have any problems with the kit either.
I do not recommend installing an egr delete kit without knowing what the health of your oil cooler is.
Old 10-02-2011, 04:57 PM
ok cool thats what i wanted to know. About how hard is it to do? and rough time estimate on doing it?
Old 10-02-2011, 05:00 PM
depends on your skill level and if you have the right tools.
Plan on around 6 - 8 hours
Old 10-02-2011, 05:09 PM
ok cool thanks for the help.. a few of my buddies are diesel techs so that should help..lol
Old 10-20-2011, 03:31 PM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Originally Posted by NYC F-350 View Post
Not very hard
I searched for dicad-solutions and came up empty, there are other sellers though. Everything that I have read says that I need to leave the EGR plugged in and in the manifold to avoid complications with the cooling fan. So, all my delete kit needs is the up pipe and the cooler re-route.
Old 10-20-2011, 03:38 PM
Keep in mind if you install an egr delete on an 05 you might have a check engine light that you will have to contend with. The need for a SCT tuner and custom tunes will come into play...
Old 10-20-2011, 03:41 PM
Yeah, I've been talking to Mike at Gearhead about my SCT tunes...he didn't say anything to me about it, but I have heard that he writes it into the tunes to deal with the CE light as long as you have an EGR delete.
Old 10-20-2011, 03:46 PM
Yep Matt is the man when it comes to custom tunes!! I know that guys talk about running SAFE tunes with no studs, but not sure Im convinced. Seems like anytime you start bumping power it could cause issues down the road, unless the motor is built for it.
Old 10-20-2011, 03:57 PM
Egr delete is not hard. Curious what is your ect/eot delta? If I was going that far I would put in a new oil cooler unless I knew it was near perfect.
Btw are you in Covington Michigan?
