sct x3 or sf3? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-01-2011, 07:10 PM Thread Starter
sct x3 or sf3?
which is better for custom tuning the sf3 of the x3 from sct?
deathstroke97 is offline
post #2 of 6 Old 10-01-2011, 07:48 PM
PerformanceMachineMFG's Avatar
Not the best on this but from my understanding you can do the same with both, one comes with custom tuning or "blank" and the other comes with 3 "can" tunes and is also capable of EGR delete out of the box.
Can call and talk to our tech guys Monday if you'd like.
Also, this upcoming week we are offering free next day air on SCT products.
-Matt H
Performance Machine & MFG.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
PerformanceMachineMFG is offline
post #3 of 6 Old 10-01-2011, 08:02 PM
mcflan's Avatar
Feedback Score: 9 reviews
You can't delete the EGR unless you physically do it. X3 is better in my opinion. The canned tunes are ****e. I've tried them and they are of little comparison to good custom tunes. Either way, you're spending 300 plus for a tuner and another 100+ for custom tunes. But its the best investment you can make.
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Banks Monster Exhaust
Isspro Gauges
Studded, Lapped, and Bored
175cc Injectors
Powermax Turbo
Blue Spring FPR
Diesel Site Coolant Filter
AD2 Fuel System
Oil By-Pass System
My personally made Remote FICM/Board
mcflan is offline
post #4 of 6 Old 10-01-2011, 08:05 PM
I didn't mean it would physically delete it. I meant it has the option to turn EGR system off when you do physically delete it.
-Matt H
E-mail:
post #5 of 6 Old 10-01-2011, 08:08 PM
mcflan's Avatar
All SCT's are blank. It's just the buyers discretion as to what to put on them. You can only load 3 tunes at a time (on an SF3 or X3). The SF3 comes with canned tunes, occupying three of the slots; meaning you can't have custom tunes unless you remove them from the tuner.
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Isspro Gauges
175cc Injectors
Powermax Turbo
Blue Spring FPR
AD2 Fuel System
Oil By-Pass System
mcflan is offline
post #6 of 6 Old 10-01-2011, 09:36 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
What.....?
The SF3 and original X-3's Will hold canned and custom tunes at the same time. You are able to store 3 custom tunes and 5 canned tunes, that's a total of 8 tunes stored in the device for your use. The canned tunes are as followed.
Trans only tune
Towing 50hp
Towing 65hp
Street
Performance
To the OP, the canned tunes are "OK" but they don't compare to a custom tune. Once you try a custom tune, you'll almost never use a canned tune again.
As far as your original question, they are both equal in programming in a custom tune. The only difference is, the SF3 can/will hold canned and custom tunes, and the new style X-3 only holds 3 custom tunes.
If your looking to buy a SCT device used, there are some things to look for.
What to look for when buying used SCT for 6.0
Another thing to look out for when buying used is, sometimes the seller will sell the SCT device with custom tunes already on it. These tunes might not work on your truck strategy, now there are some strategies that are compatible with others, but unless you know for sure don't risk loading them into your truck. You might end up "locking out" your truck, in other words, it won't start or return back to stock so your stuck having to tow the truck to a dealer for the PCM to be reflashed for a fee.
You can read this info from Ken@SCT on post #1.
http://www.powerstroke.org/forum/sct...s-answers.html
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
