SCT Live Wire Install help
I keep following all the instructions and have done it several times, but it always gets stuck after updating ECU when it goes to storage setip. It gets to 99% and then gives a error 1035 code. I can not get it any further... Help
Only like the 10th time after resting it to stock it worked!
Glad it worked out for ya...Just picked up my Livewire today and with the canned tunes; Hell YEAH..........Got a manual so I ain't worried about the tranny; I am worried about the stock clutch so I ain't getting on it too hard yet and I really don't need to.
Also what I thought was an induction leak is gone, was only building 21-22psi. Now I hit 28psi no problem, must not have liked the EGR delete or something...Heard that could cause a boost problem. I need to find something to tow so I can try out the Jake (turbo) brake. Oh and it must fuel more or something off throttle. Seems like I have less compression to slow it down when I let off...But on the positive side it makes shifting without using the clutch way smoother. Before the extra tension on the drivetrain made me have to be a lot more precise with the RPMs to avoid missing or grinding gears. Now no miss, no grind. Which equates to longer lasting clutch
