Anyone using the SCT9600 programmer?
I've posted this before with no response. Installed the SCT 9600 programmer and the instructions suck. Can't figure out how to change modes from performance to street to tow. Also keep getting a P0102 code indicating a low input on MAF sensor. Changed sensor and code keeps returning. Any insight would help.
Flash it back to stock. Then got in to program setup, select one of the customer or canned tune options, then under user settings adjust it, in that setting area there will be a setting for tune type press the wheel and it will bring up all tune types... From there youpick the one go back and you can mode the tune through the other settings below.
That did the trick. Thank you. Have you had any problems with the MAF?
Nope, but it has only been in for about 24 hours of which I finally got it right about 5 hours ago
