Will it lower my egt's??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-29-2011, 01:54 PM Thread Starter
Rjstepp's Avatar
like it says if I delete this
[IMG][/IMG]
will it lower my egt's or just make the turbo whistle louder, it's the 03 turbo silencer, kitty already ran away
Rick
2003 F350 cclb 6.0l 126,000 miles
SCT X2 running matt's srl
edge insight cs, egt probe
egr delete
Sinister coolant filter
4" turbo back diamond eye exhaust
smoked cab lights and mirror lens
Cut '05 grille and rhino lined bed
Leveled on 35" toyo m/t's
Rjstepp is offline
post #2 of 6 Old 09-29-2011, 02:19 PM
DoubleDpsd's Avatar
I want that if you cut it off! It's a resonator. It will lower egt's post turbo and it will whistle, a lot....so much that after 6yrs of no resonator I'm looking for one!
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 6 Old 09-29-2011, 02:49 PM
I've debated cutting my off for awhile and from what I read it get pretty loud crusing 75 mph my exhaust is not all the way out the back or I would have done it less restriction th better
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #4 of 6 Old 09-30-2011, 01:02 AM Thread Starter
Rjstepp's Avatar
I'll hit you up if I do cut it off, looking at getting a used stack kit and if that happens it may go away. My exhaust doesn't go all the way out the back at the moment either.
Rick
egr delete
Rjstepp is offline
post #5 of 6 Old 10-01-2011, 07:59 PM
jerg_064's Avatar
With the DP curving immediately (so it seems) on the turbo side of the resonator, how do you plan to/how have others connected the DP pre-resonator to the rest of the exhaust?
Pics would be great for those that have done it...I'm more so debating on just getting an aftermarket DP unless this is easier done than it looks.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #6 of 6 Old 10-01-2011, 10:45 PM Thread Starter
Rjstepp's Avatar
Looks like it gets fairly flat, or possibly close enough that another pipe might be able to be welded in. have to get back under there and look closer when I get close to doing something with it.
Rick
egr delete
Rjstepp is offline
