Blue spring installed! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-23-2011, 05:40 PM Thread Starter
stroKR20's Avatar
Installed my blue spring today. I must say that I noticed a definite improvement in throttle response. It was real easy and I wouldn't have even known the difference in springs if I didn't do the upgrade. When I installed it I skipped the step of taking of the secondary fuel filter housing cap and draining the fuel from it.. I unscrewed the side cover to get access to the spring, stuffed some rags under the housing and pulled the spring w/ brass cup and had some fuel leak out...not even enough to drain through the rags though. All in all took about 30-45 mins in the blazing Georgia heat. Very happy with the upgrade and the truck seems to run so much better. Thanks to all the guys who have done the write-ups because I read over them multiple times to make sure I had the process down pat.
08 F350 CCSB- MiniMaxx, 5" SS DP back DiamondEye, S&B Intake and 35" Toyo MT's, 6" BDS lift
2006 250 KR (SOLD)
stroKR20 is offline
post #2 of 6 Old 09-23-2011, 05:57 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
it's definitely one of those things everyone should do
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 6 Old 09-23-2011, 06:06 PM Thread Starter
stroKR20's Avatar
Here's a question for you Sinner, since you're here. I bought the full kit from Tousley Ford, is it a big deal that I left the puppet valve that was already in there and the stock cover on? I looked at them as close as I could and searched around and couldn't find a reason that made me feel I should have to replace it...
2006 250 KR (SOLD)
stroKR20 is offline
post #4 of 6 Old 09-23-2011, 07:16 PM
If I have new, it gets it...................
Aussiekeeper is offline
post #5 of 6 Old 09-23-2011, 07:37 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Nah I wouldn't worry about it, I doubt it's really a wear item
-Matt
2015 F-250 XLT 6.7L
post #6 of 6 Old 09-24-2011, 06:35 AM Thread Starter
stroKR20's Avatar
I was just bein lazy cause it was hot as the devils backside out. Never hurts to have spare parts. Thanks
2006 250 KR (SOLD)
stroKR20 is offline
