True twin turbos? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-22-2011, 05:11 PM Thread Starter
kdogg85's Avatar
True twin turbos?
Any of you guys runnin' compounds have any idea how this would work?
I only ask because I have read people asking about using two stockers and that would be way too big to spool.
Could something around the 30-40mm range do the job? I would figure those would be small enough for each side of the engine to spin up pretty good. I also would assume the intake manifold would have to be something like the banks big hoss seperating each intake tract.
Just asking like someone would with more money than sense.
kdogg85 is offline
post #2 of 12 Old 09-22-2011, 05:19 PM
Chiller's Avatar
They do make kits for the 6.0.... I have tunes from innovated kinda why i picked their set up to run when I eventually cross over to the other side. I dont think you could use to stock turbos. to bigg and no way to control vaines on both. Here is a link to the kit. They have race and tow versions.
Ford 6.0L Compound Turbo Kit
2005 F350 4x4 CC LB Lariat
Engine: Puking ModIntake, Innovative SCT Tuned, Straight Pipe, Zoodad, DIY CCV.
Exterior: 8inch Rize 4Link, traction bars, Deaver Leafs, Raceline Rims, 37inch Toyos M/Ts, Leer Cap, Bushwacker Pocket Flares, Tints, Lights and little stuff
Interior: Isspro Gauges, Leds bulbs , Livewire, Overhead DVD, Aftermarket alarm/remote start
Chiller is offline
post #3 of 12 Old 09-22-2011, 05:23 PM
06powerstroke06's Avatar
There was a car with a 6.0 in it in diesel power couple issues back that had true twins on it. I think they were 52mms from a porsche or somthing
06powerstroke06 is offline
post #4 of 12 Old 09-22-2011, 05:25 PM
66Bronco's Avatar
I think he means a bi-turbo setup instead of compounds. Could be interesting...
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #5 of 12 Old 09-22-2011, 05:28 PM
matty21's Avatar
why? the piping alone for the manifolds would be stupid-crazy (and tight). then theres the matter of two wastegates, getting them balanced and set the same. then the cold side piping- two intercoolers or a huge single core with dual inlets. Oil lines, oil drain lines coolant feed and return lines, ALL X 2. then converging the two down pipes. finding space for two air filters and/or piping. all that gear in such an impossibly sized space is destined for heat issues. all for no increase in performance over a well balanced compound setup
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #6 of 12 Old 09-22-2011, 05:30 PM
66Bronco's Avatar
Probably mainly because nobody's done it in a SD before. Compounds are slick, but they're pretty commonplace in the aftermarket. Innovation is bred by daring to be different.
'95 F-250HD
B&W Gooseneck
66Bronco is offline
post #7 of 12 Old 09-22-2011, 06:32 PM Thread Starter
kdogg85's Avatar
Why not try what sts has done and mount the stuff under the truck. There is plenty of room. I am not saying mount the turbos at the back and have 2 miles of piping ran, but around the area where the tranny meets the engine.
Why would there be no increase in performance? A compound setup works great for what it is but, 2 turbos in series has it's limitations. One trying to suck air through the other and one trying to push air through the other. This setup would eliminate some restrictions compound setups have, in theory of course.
kdogg85 is offline
post #8 of 12 Old 09-22-2011, 06:33 PM
thesmokinstroke02's Avatar
would it be to far fetched to think you could run a charger off each bank and then have that feed into one big charger. like a triple turbo setup.
Konnor
2011 Cruze
R.I.P. Will Iott
thesmokinstroke02 is offline
post #9 of 12 Old 09-22-2011, 07:22 PM
Glueballs's Avatar
You could setup twins two ways:
1. The way I prefer where you have separate banks on the engine a left bank and right bank of cylinders. You run completely separate intake and exhaust systems. This is the best setup for balancing your turbos and making the most power. It is also the most expensive and time consuming method with tons of custom/modified parts.
2. The second method is to have two turbos each fed by a bank of cylinders on the exhaust side. You can tie the outlets together or leave them seperate. On the boost side you combine your turbo's upstream of the intercooler and you only need to run one waste gate on the boost side. This allows you to only use one MAF sensor and eliminates alot of the custom piping and manifolds. However you can probably make the same horsepower on a compound setup with faster spooling.
Here is a good website for sizing turbo's Borgwarner MatchBot
I did a quick match for a 6.0l running twins. 6.0l twins The calculated outputs are in the first expandable area. As you can see you can make more power with the compounds if you want quick turbo response.
Greg
"You are not thinking. You are merely being logical."
Niels Bohr
06 F350 Amarillo CCSB - MODS - Bulletproof 6phase FICM 58V, Odyssey 65-PC1750, SCT iTSX Tuned, EGR delete, 4" with Cat and Muffler - To be installed - Bulletproof Oil Cooler, Regulated Return w/ fuel bowl delete and FASS.
Last edited by Glueballs; 09-22-2011 at 07:23 PM. Reason: Deleted a bracket on one of the links
Glueballs is offline
post #10 of 12 Old 09-23-2011, 03:46 PM
jerg_064's Avatar
Isn't the 6.4 turbo setup basically true twins? Same input/output airflow.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
