How streetable is 1000tq@wheels? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-20-2011, 01:43 AM Thread Starter
My 04 f350 is my first diesel and it's been a lot of fun. The egr is deleted, oil cooler replaced, straight piped 4", sct tuned, edge cs, cat elc, shell rotella.
I've been collecting parts when ever I get enough downtime to get my head studs done. So far arp head studs, stock f350 gaskets, comp valve springs, forged stock rods.
I kinda of have a goal of 1000tq, no real why. Would a set of 215cc injectors, a 66mm non vgt turbo, regulated fuel return, FAAS. With my collection of parts get me somewhere around there? (aftermarket tranny will be purchased)
Also HPOP and LPOP will be looked into, not tootoo much research on the requirements of them yet.
20046.0 is offline
post #2 of 16 Old 09-20-2011, 04:20 AM
06powerstroke06's Avatar
Haha a set of 190s and powermax would have got you over 1000ft lbs! I made 490/945 with that combo a year ago and it should have been in the 550 range so that's over 1000 ft lbs. You were no where near needing rods. And if your getting the springs do you have the shims? What about chrome moly push rods? But again all this isn't needed at that power level. But isn't a bad idea.
215s and a 66 will get you 600-630 range on hp and 1200 range on torque. Ball park est.
You won't need oil upgrades at that level.
06powerstroke06 is offline
post #3 of 16 Old 09-20-2011, 04:47 AM
Country Mav's Avatar
Quoted: 2 Post(s)
Good grief these things make power!!!
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
post #4 of 16 Old 09-20-2011, 04:50 AM
Haha that's nothing. I'm gunning for 1000+ rwhp
post #5 of 16 Old 09-20-2011, 05:21 AM
mdub707's Avatar
A powermax and 190's should have you real close, and still be very drivable.
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
post #6 of 16 Old 10-06-2011, 10:39 AM
Baddestt's Avatar
Quoted: 8 Post(s)
Ummm, yeah, these 6.0 liters can make tons of torque with the right equipment, it's insane the amount of power they can make.
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #7 of 16 Old 10-06-2011, 02:50 PM
jerg_064's Avatar
So then, besides studs and the other basic preventative maint stuff what is needed to run 1000rwtq with 190s & powermax? Ugraded fuel system & clutch(stick shifter here)?
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #8 of 16 Old 10-06-2011, 03:59 PM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Just speaking from experience, you may want to think about a new rear end; the stock one doesn't seem to like that much power. I like my Detroit Tru-Trac but there are lots of options.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #9 of 16 Old 10-06-2011, 09:46 PM Thread Starter
regarding oil upgrades would that just be a higher output hpop then? Is there any vendor that makes say a valve train upgrade kit? Could I do 700hp with larger injectors and turbo? I dont want to bore it or change cams. Money isn't a big deal most of my truck parts are a business write off
20046.0 is offline
post #10 of 16 Old 10-07-2011, 07:35 AM
You are going to want to spray it to get 700. Getting 700 on fuel would require a big laggy turbo. Unless you go compounds.
You can get valve train upgrades but it's really not needed. I just built mine up because I have the motor tore completely apart and it is just good insurance.
