can anyone help a future stroker owner with an oasis
I'm looking for an oasis report on VIN 1FTSW21P97EA39424
2007 F 250 King Ranch fx4 srw short bed. Has a small ding in the passenger side of the bed but nothing that can't be fixed easily. 109k for 19,000 Just trying to find out if it has had any major issues. |
Any ford dealership should be able to look it up for you. I just asked the guys at the parts counter and they printed it right out for me and explained what everything meant.
Good luck! Sent from my Autoguide iPhone app |
x 2 I am taking a vin # by the local dealer tomorrow.
Looking at an 06 CCLB Dually 4x4 lariot 180K miles Bully Dog Chip, egr delete, 22.5's, firestone bags, 5in silver line, new turbo and tranny for $15,000. I was told a sensor went out on the tranny and it started acting weird so PO hammered on it under a 30,000# load and tore it up. The dealer told him the Turbo was bad when he got the EGR delete and the owner had a friend replace the turbo. They had the same amount of play and he is giving me the old turbo with the truck. I feel like its my B-Day... I don't really like bully dog but I guess its better than stock for now... I like custom tuning better (I had a D-Max with EFI live once upon a time but a divorce and the debt monster took it away) GOOD LUCK with your purchase! |
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FTSW21P97EA39424 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JUN-2006 14-AUG-2006 123275 USA 34 1H03 030008 5C3Z 9F452 AA E29 41 67723 AWS Claim Key: 4622574 Trx Code: S07 Labor Hrs: 1.2 Dlr Cd-Sub Cd: 06443 - * Name: BOLTON FORD, L.L.C. Ph: 337-4740070 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2009 Doc #:09260801 Cust Comments: CHECK ENGINE LIGHT ON Tech Comments: EGR VALVE STICKING EEC TEST P1335 PINPOINT. DLC MONITOR FOUND EGR VOLTS. 1.12 WITH VALVE COMMANDED SHUT. REMOVED VAVLE AND IT WAS STUCK OPEN. REPLACED EGR VALVE CLEARED CODES. RETEST OKAY. -------------------------------------------------------------------------------- 1FTSW21P97EA39424 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JUN-2006 14-AUG-2006 123275 USA 36 1H03 030008 5C3Z 9F452 AA E29 42 71698 AWS Claim Key: 4889587 Trx Code: E91 Labor Hrs: 1.1 Dlr Cd-Sub Cd: 06443 - * Name: BOLTON FORD, L.L.C. Ph: 337-4740070 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:09-JUL-2009 Doc #:09509701 Cust Comments: CHECK ENGINE LIGHT WAS ON BUT WENT OFF Tech Comments: VALVE STICKING OPEN EEC TEST P0403 P0404, USING IDS PERFORM EGR VALVE RESPONSE TEST, VALVE FAILED, REPLACE VALVE. CLEAR CODES RETEST OK TEST DRIVE OK -------------------------------------------------------------------------------- 1FTSW21P97EA39424 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JUN-2006 14-AUG-2006 123275 USA 36 1B03 030204 3C3Z 6A642 CA L87 D8 72272 AWS Claim Key: 5024449 Trx Code: E72 Labor Hrs: 9.5 Dlr Cd-Sub Cd: 06443 - * Name: BOLTON FORD, L.L.C. Ph: 337-4740070 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2009 Doc #:09599302 Cust Comments: BLOWS BLACK SMOKE Tech Comments: OIL COOLER RESTRICTED CAUSING EGR COOLER TO BURN TEST DRIVE, ENGINE IS VENTING COOLANT OUT DEGAS CA P AND BLOWING WHITE SMOKE OUR EXHAUST. FOLLOW TSB 09 8 3, PRESSURE TEST EGR COOLER FAILED. SUBMIT PR IOR APPROVAL CODE: PAARN. REPLANE EGR COOLER AND O IL COOLER KIT. FLUSH -------------------------------------------------------------------------------- 1FTSW21P97EA39424 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JUN-2006 14-AUG-2006 123275 USA 36 1H03 030008 5C3Z 9F452 AA E29 42 72272 AWS Claim Key: 5024448 Trx Code: E91 Labor Hrs: 1.1 Dlr Cd-Sub Cd: 06443 - * Name: BOLTON FORD, L.L.C. Ph: 337-4740070 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2009 Doc #:09599301 Cust Comments: CHECK ENGINE LIGHT Tech Comments: EEC TEST P0403 P0404. R&R EGR VALVE FOUND VALVE IS CARBONED UP, FOLLOW TSB 8 26 12. REPLACE EGR VALV E AND INSTALL EGR BAFFLE KIT AS DIRECTED BY TSB. R EPROGRAM PCM, TCM, AND FICM AS DIRECTED BY TSB. CL EAR CODES RETEST OK TEST DRIVE OK -------------------------------------------------------------------------------- 1FTSW21P97EA39424 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JUN-2006 14-AUG-2006 123275 USA 37 1B03 030204 * 6A642 * L65 D8 72868 AWS Claim Key: 5142192 Trx Code: E88 Labor Hrs: 5.8 Dlr Cd-Sub Cd: 06443 - * Name: BOLTON FORD, L.L.C. Ph: 337-4740070 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2009 Doc #:09717801 Cust Comments: ENGINE HAS OIL LEAK Tech Comments: GASKET CUT DURING ASSEMBLY -------------------------------------------------------------------------------- 1FTSW21P97EA39424 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JUN-2006 14-AUG-2006 123275 USA 38 2E01 03XXXX * 9B246 * D21 42 73021 AWS Claim Key: 5166780 Trx Code: E72 Labor Hrs: 2.3 Dlr Cd-Sub Cd: 01196 - * Name: HOLLINGSWORTH RICHARDS FORD Ph: 225-9275555 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2009 Doc #:60099301 Cust Comments: CUST. STATES VEHICLE STALLED AT HWY SPEEDS AND NOW WILL NOT RESTART JUST SPINS OVER Tech Comments: VERIFY CONCERN EEC TEST PPT MONITOR PID DATA P2291 INSPECT TEST AND REPLACE IPR SEE TSB 08 18 06 ATTACHED CLEAR CODE RETEST TEST DROVE OK AT THIS TIME |
