Heads/Block question ! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-12-2011, 09:45 AM Thread Starter
Dropped my truck off at shop for head gaskets & studs. Repairs shop started to talk about blocks can be washed out where gaskets leaked . Is this a common problem and if so ?? what do you do ?? Buff it down as clean as possible and hope they hold ?? O-Ring the block ?? I know some racers that do this without tearing down the short block and have the tools to cut them ..How often if any is this possible of happening ??
'05 F250SD > Ranch Hand HD Bumper w/skid plate & KC's, 2.5" Leveling Kit, Firestone Rear Bags, 305/17 Goodyear Wranglers, Hide-a-Ball Hitch, SCTx3 by Vivian , EGR Delete, 4" open exhaust , 6.4 Banjo Bolts , Fuel Reg. upgrade kit , cold air intake by me , '03 Turbo by HPTurbochargers,46 gal.aux.tank, ARP Studs / Factory Gaskets.
Rmorgan711 is offline
post #2 of 4 Old 09-12-2011, 10:11 AM
06powerstroke06's Avatar
no need to o right the heads. Just plane the heads and bolt her down.
06powerstroke06 is offline
post #3 of 4 Old 09-12-2011, 11:52 AM Thread Starter
so < blocks are pretty stout ? and enough meat between cylinders not to worry about piting or slight erosion ?
post #4 of 4 Old 09-12-2011, 12:03 PM
well anything can happen but its more common for your heads to be warped or cracked.
