Head gaskets - Ford Powerstroke Diesel Forum
Old 09-01-2011, 04:23 PM
Head gaskets
Ok I blew my studded head gaskets(black onyx)... Truck uses about 2 gallons of water a day now. Any suggestions on better gaskets? Also what's it cost ballpark for heads to get milled and checked?
Old 09-01-2011, 04:46 PM
Were they checked the first time you did them?
Lots of people say that the factory gaskets are best, but if you properly check the heads you should be good.
Old 09-01-2011, 04:49 PM
Also, to get my heads milled, magnafluxed, new valve seats, 1 new valve, and the rest re- ground, it cost around $700.00.
Old 09-01-2011, 04:54 PM
No I didn't get them checked by anyone but ford. I will be taking them to a local diesel shop for them to be gone through this time. What are stock gaskets rated for hp wise? I do have some extra power.
Old 09-01-2011, 05:05 PM
Thats hard to quantify. I think the 6.0 horsepower record was made with stock gaskets, but that doesn't mean that they last any longer. (Any race motor gets rebuilt often)
Old 09-01-2011, 05:06 PM
I Love Workin On Hotrods
Well the guy who has built the most powerful 6.0L (that I have heard of being at 1000hp) used the oem head gaskets. I had mine milled, pressure checked, magnafluxed, flatness and straight checked, valve job, and new guides and seals installed and it cost me just under $1000.
Old 09-01-2011, 08:06 PM
Odds are the block and heads were not properly cleaned or the head was out of spec. Not saying the gaskets cant fail but I assure you if the heads were torqued properly there is more than likely another reason.
Old 09-01-2011, 08:10 PM
id go stock gaskets. it seems like the black ones are dropping like fly's. heres Shawn Ellerton's truck its got stock gaskets
Old 09-03-2011, 10:27 AM
so stock gaskets are the way to go? what is everyone else running?
Old 09-03-2011, 10:37 AM
OE gaskets for sure!!
