Pick me out a turbo! - Ford Powerstroke Diesel Forum
post #1 of 18 Old 08-31-2011, 03:02 PM Thread Starter
Just replaced a ton of crap on my 6.0L and for the sake of it I decided to take apart the turbo to clean it. Well here is what I found......
Not sure how long its been like this or when I happened. It doesn't look fresh to me though.
Anyways if you were to go buy a new one..What would you get? The main use for this truck is towing a 11,000lb Gooseneck. So I don't need anything crazy.
2005 F350 Dually, PowerMax, SCT Tuner, GearHead Tunes, Blue Spring Mod, Banjo Bolts, 22.5 American Force Wheels, 4.88 Gears, Edge CS Insight with EGT, Full Carbon Fiber Vinyl Wrap, MBRP Exhaust, EGR Delete, ARP Headstuds, Updated STC, Standpipes and Dummy Plugs, AirDog II (second pump
), 4" Lift to clear the 37 x 22.5s, Air Lift helper Bags,
cf7go is offline
post #2 of 18 Old 08-31-2011, 03:03 PM
Pretty badly chipped. Ive got one for sale, it's an upgrade from the original turbo but bolts in just like stock, it's a industrial injection turbo, flows 300 cfm more than stock. $800.
SRT-Diesel is offline
post #3 of 18 Old 08-31-2011, 05:01 PM
Fred@PMM's Avatar
Powermax FTW! 6.0L Garrett PowerMax GT3788VA 88mm Turbo (04-07 Models) - 772441-5001S
Performance Machine & MFG.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
Fred@PMM is offline
post #4 of 18 Old 08-31-2011, 05:34 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
If I were in your shoes I would go with the powermax. It isnt anything crazy and will do what you need it to do and still be able to allow you to increase power later on if you wish to add larger injectors.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 18 Old 08-31-2011, 05:57 PM
So does the industrial injection...
post #6 of 18 Old 08-31-2011, 06:39 PM Thread Starter
Well either way I go I want to keep the injectors stock. Because I just put on the Valve covers today. I am sick of working on this thing this week. The new standpipe on the passenger side sucked to install. But now I have a sweet new tool I made to get the two torx bolts out that are next to the heater box.
Either one of those turbos seem good to me. Not looking for crazy power upgrades. Just something better than stock. Im just really boggled on what the hell went through the turbo. I just probably leak down and compression test it before I fire it up with a new turbo on there.......
I should probably order some custom tunes for my SCT too then......$$$$$$$
cf7go is offline
post #7 of 18 Old 08-31-2011, 08:27 PM
FourFun's Avatar
Powermax and tunes from gearhead. I love it!
04 6.0l Excursion
4x4
6" Lift, 35' BFG's, Powermax
AFE Intake, CFM+
Swamps 58v ficm, ARP, EGR delete
Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro
4"MBRP SS exhaust cat/muffler delete
6.4 banjos, FPR spring upgrade
Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod
07' Harley headlights, 08' Tow mirros
Hellwig swaybar, Billstein 5100's
FourFun is offline
post #8 of 18 Old 09-01-2011, 05:02 AM
work&play's Avatar
Quoted: 2 Post(s)
I love my Powermax with stock sticks and tunes from Matt.
It sounds great also.
2007 6.0 PSD,F350 4X4 Lariat,CC, DRW,9' Knapheide body, stainless steel lader rack, SCT with custom tunes, ARP's, EGR delete, ITP RR, Airdog II 130/75, Garrett Powermax, Banks turbo back, Firestone air bags, Autometer gauges
work&play is offline
post #9 of 18 Old 09-01-2011, 06:28 AM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
PowerMax will be your best bet. $1100 and no core charge for a brand new turbo. The Industrial Injection turbo is not much bigger than stock, the PowerMax is a 63mm or a 64mm turbo and will lower your EGT's a good bit while towing. If you've got the cash, get the Batmowheel for it too, it will increase power, give you faster spoolup, and even lower EGT's.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #10 of 18 Old 09-01-2011, 06:46 AM
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Feedback Score: 4 reviews
I am also running the PowerMax with stock sticks. My Looney from Vivian at QuickTricks has been updated to match the PowerMax turbo and it runs great. I love the sound as well.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
