Bully Dog install
Quick question peeps! OK i'm I installed my bully dog programmer but it so happened that i used the wrong fuse location because I can't get my programmer to shut off. I currently had it connected to the passenger fuse panel under the ignition fuse but it seems to run 12v constant. Does anyone know where I can connect the Programmer so that it shuts off when I turn off my truck. Thanks all.
Manny
I read your other posts, if you have an 2008, your in the wrong section. You need the 6.4 threads.
Welcome to the Org!! |
If its a 6.4L use capped off purple wire under the drivers side dash. Hope this helps! |
