Powermax boost with stock tune? - Ford Powerstroke Diesel Forum
Old 08-29-2011, 06:08 AM
Turbos = Witchcraft
So the powermax is in and I am waiting on my custom tunes from Matt.
While I wait, I am just running the truck with the stock tune (The canned tunes on the SF3 are useless IMHO, smokes like a freight train and twice as slow)
I have heard that the powermax without tunes is super laggy and smokes a lot which is definitely true in my case, especially with my 190s. My concern is that right now at WOT I still only see 10-12 psi while my stock turbo would hit 35 psi with the 190s and stock tune. Has anyone else experienced this? Do you guys think there is something wrong with the truck or am I just worrying too much? I want to make sure everything is good to go before I load up the custom tunes.
Old 08-29-2011, 06:32 AM
Slacker
Feedback Score: 4 reviews
Wait until you get the custom tunes. It's likely operating outside of it's efficiency range or you could also have an exhaust leak, but you won't be able to confirm until you get tunes designed for the PM.
Old 08-29-2011, 06:41 AM
Turbos = Witchcraft
Thanks! Wouldn't I be able to see if I have an exhaust leak now?
Old 08-29-2011, 06:48 AM
Slacker
Yes, most likely. Looks for telltale signs of soot around the up-pipe, paying particular attention to the flex section and the EGR cooler clamp area. You will need a high powered flashlight and a mirror to see all around both areas.
Old 08-29-2011, 07:26 AM
Turbos = Witchcraft
Thanks! I'll check it out and wait for my tune
Old 08-29-2011, 07:35 AM
Custom tunes are a must with those injectors and Powermax. I bet once you get those youll be much happier
Old 08-29-2011, 08:08 AM
Turbos = Witchcraft
I agree! I should be getting my tunes from Matt very soon lol I'm just impatient
Old 08-29-2011, 01:37 PM
Worrying too much When people say the PM is laggy without tunes there is probably good cause they are saying it, you've found it to be true!
Mine acted the same way, and after the proper tune it was a totally different truck..
Old 09-02-2011, 11:03 AM
Turbos = Witchcraft
Thanks for the input guys!
I am loading up the SRL+ for PM today and test it out this weekend.
I can't wait!!!
Old 09-06-2011, 05:14 AM
Turbos = Witchcraft
Ok, so I loaded up Matt's Tunes this weekend and nothing has changed
I spent over an hour trying to find some kind of an exhaust leak but I can't find anything. The manifolds and up-pipes look clean. With the amount of smoke that is pouring out of the tailpipe you would think I should be able to see some soot if there was a leak someplace. Does anyone have any other suggestions?
I think I may need to seek professional help
