fuel system - Ford Powerstroke Diesel Forum
Old 08-28-2011, 08:04 AM
fuel system
When I buy my Air Dog can I just remove my fuel bowl and put in a "Y" off the main fuel line?
Old 08-28-2011, 08:29 AM
You would need the AirDog II that has the built in regulator. Set it to 60+ PSI for best results. Adjust as desired for best performance.
Old 08-28-2011, 01:41 PM
I am going to get an Air Dog 2. 190cc injectors and a modded 68mm power max should be good for 600hp from what I was told. I was also told I can tow my 4-5k lbs lawn trailer. We will see how that works out.
Old 08-28-2011, 02:29 PM
I Love Workin On Hotrods
I would suggest staying away from such a large wheel VGT turbo. They typically dont hold up well because they are prone to surging which causes the bearings to fail. I would just stick with a powermax and add a batmowheel and call it a day.
Old 08-28-2011, 03:53 PM
what will the batmowheel add to the Powermax?
Old 09-03-2011, 04:20 PM
how much is the powermax with the batmowheel?
Old 09-03-2011, 06:22 PM
The powermax with 190's yielded a 35whp gain.. no torque numbers but from comparisons its seems like it falls the 150 tq gain.
Powermax = $1200
Batmowheel = $400
So for $1600 or so you have a BRAND NEW turbo that will last longer than a modded elite or RCD turbo, have no surging issues, and youll have basically stock like spool up
no brainer to me, you couldnt pay me to run a 68mm vgt from rcd or elite
Old 09-03-2011, 07:02 PM
Powermax = $1200
Batmowheel = $400
I'll second that.
Old 09-03-2011, 09:05 PM
That and you dont have a core charge with the powermax so you could rebuild your stocker and put a batmowheel in that also.....that way if the powermax takes a dump on you its posible to just switch them out same day and still run a modded turbo for the 190s
Old 09-03-2011, 09:09 PM
Originally Posted by PGreenSVT View Post
I'll second that.
Yah, there is a good reason why a big name performance company that is three letters long starting with an "A" no longer makes a variable vane turbo setup anymore. Tell me more about this Batmowheel and where to get it or who sells the whole setup.
