Edge Tuner - Ford Powerstroke Diesel Forum
Old 08-19-2011, 12:40 PM
Edge Tuner
I'm working on upgrading everything necessary to make my wife's Excursion we just bought the most dependable it can be. I've already changed to synthetic oil and changed the fuel filters. I've read to add guages as soon as possible and have read that Edge tuners and guages are the best for the 6.0.
My question is which Edge product? My primary desire out of the engine is to increase fuel mileage. What would be my best deal for the money? I know that I want to have the monitor for reading the turbo temperature.
Also, I plan to change to aftermarket wheels and tires on the truck. Are these tunes adjustable down to wheel and tire size post purchase? Or should I have the wheels and tires on the truck before buy the tune?
Thanks for the help.
Old 08-19-2011, 12:49 PM
Edge tuner is a NO NO!! a custom tunes sct. X3 is the only way to go. edge tuners dont tune the trans. so with added power your transmission gets destroyed. as far as gauges go a edge insight are awesome.
depending on how you feel about it having a bunch more power. a higher hp tune will get better mpg and it will be much easier to drive. Slr tune from matt@gearheadautomotive is the best hands down!
what about the exhaust ect... all stock?
Old 08-19-2011, 12:57 PM
Gotcha! I got the names confused....
I'm completely down with having a lot more power so long as it's not at the expense of mileage. This is my first diesel so I'm not used to the more power and more mileage going together!
As far as exhaust goes, I've had the cat cut off, but I want to run exhaust all the way from the turbo. I having trouble finding a shop around me that's experienced in diesel exhaust though.
Old 08-19-2011, 01:02 PM
this is what i recommend: SCT X3 Custom Innovative Diesel Tuning/ Edge CTS combo
as far as exhaust goes.. its something you can easily do in your driveway.. no need to pay someone to do it
-Raul
Old 08-19-2011, 01:03 PM
the exhaust is fairly easy to do yourself if you are somewhat mechanically inclined. with the cat cut off you will be fine as long as you dont tow.
diesels are funny more power= better mpg. but its true. me running a 170hp spartan tune. will get 20-22 Mpg all day on the interstate even 23 occasionally.
now if you get gauges. you will need to check out your oil cooler situation. if its plugged your going to need to replace it or. your egr cooler will blow. then your burning coolant and a blown head gasket.
heres some reading from another member...
**Premium Member** PowerStroke.org - Forum
PGreenSVT
Here is the deal with the 6.0. Any good tuner (person writing your tunes) is not going to give you a tune that is going to tear up your truck. There are trucks all over the place running 400-420 rwhp with 750-800 rwtq all day long without problems.
Yes the 6.0 is known to blow head gaskets. This is why it happens. The Ford Gold coolant contains silicates. The silicates are not able to handle high EGT's generated by a good load or relatively high boost when they run through the EGR cooler. They break down into a gell like sludge and fall out of suspension. This crud gets caught up in the tiny coolant passageways of the oil cooler. As the cooler clogs up it restricts coolant flow to the egr cooler. Now the egr cooler doesn't have enough coolant to carry off the heat generated by high EGT's. The limited amount of coolant in the egr cooler flash boils causing high pressure in the cooling system and the truck pukes coolant from the degass bottle due to the pressure. (it has to go somewhere)
Your uninformed Powerstroke owner is not monitoring his coolant temps and oil temps so he doesn't know whats going on and he keeps driving it this way. The problem gets worse, the pressure causes the egr cooler to rupture. Now the egr cooler is leaking coolant into the intake manifold which then runs into the cylinders. Again the high combustion temps cause the coolant to vaporize. This causes unacceptably high cylinder pressure, the TTY head bolts stretch due to the add'l pressure and there go your head gaskets.
Ok now you know the problem. Here's the cure. Get a good engine monitoring solution like the Edge Insight so that you can monitor your ECT and EOT. If those temps get more than 15* apart with normal cruising when at normal operating temperature your oil cooler is clogging up. Rebuild it now to prevent all that down stream damage from occurring. Flush that Ford Gold coolant crap out of your engine with a couple bottles of Restore. This is made specifically to clean out that silicate residue. Now refill it with a silicate free Cat EC-1 rated ELC coolant. This removes the silicates that clog the oil cooler from the equation. If you live in an area where you don't have smog inspections delete the egr system. If you can't delete it replace the egr cooler with the cooler manufactured by Bulletproof Diesel. This is vastly superior to the Ford oem egr cooler and it will not fail on you. If you find that you need to replace head gaskets replace the TTY head bolts with ARP studs and use black onyx (Victor Reinz) head gaskets. If you have to replace the egr cooler always replace the oil cooler. That is the source of the problem.
Now that you have addressed the common problems that scare the he11 out of people, get an SCT tuner (i like the X3) and install some custom tunes and drive the heck out of it. DO NOT baby it. The Powerstroke hates this and will rebel with turbo issues.
Turbo issues are also common repair points with the 6.0. People like to complain that it's because the VGT turbos are pieces of junk. This is not so. The VGT vanes in the turbo need to be exercised regularly. This means making them go through their full range of motion. So put your foot in it regularly and let it see some full boost runs. That will keep your VGT vanes from getting all sooted up and freezing up because of the soot. Again, that is what happens when you baby it. Put your foot in it and you will have less problems. Lay out of it and try to milk it for mileage like you would a gasser and you're going to have turbo issues. Don't let it sit either. That is also the kiss of death to the turbo. The unison ring rusts up and again you have turbo problems. So now that you know you need to give your turbo a regular work out to keep it happy, give it a proper cool down as well. Just whipping into your parking place and shutting it down will lead to coking the bearings and again major turbo issues. Running a good synthetic oil will help here immensely because it handles heat so much better and resists coking. But always let your turbo have time to cool down. This is one of the reasons you need a Pyrometer (EGT gauge). Let the EGT come down to 350* before shutting your truck off. This only takes a couple of minutes, especially if you take it easy on it for the last couple minutes of your trip. If this is too much hassle for you get a turbo timer that will automatically delay shutdown when you turn off the key to allow the turbo to cool down.
Injectors. Ford's HEUI injection system fires the injectors with High Pressure Oil, to the tune of 4,000psi at Wide Open Throttle. Maintenance is critical here so you can not let your oil maintenance slide like you can on a gasser. It will kill your injectors. The injectors also are known to suffer from something that we call stiction. That is when the oil side plunger of the injector hangs up or sticks when cold until the truck warms up. I believe this is caused by varnish buildup that is common to dino oils, especially those containing paraffin. Using a good synthetic oil will take care of that because it actually cleans the engine as it lubricates. If you do find yourself with some injector stiction add a couple of bottles of Rev-X to your oil. It has cleared up 99.9% of the trucks it has been used on. 2 bottles run around $70. A new injector is about $250-$290. Be anal about keeping your oil clean and fresh and changing your fuel filters regularly. The other thing that kills injectors is low fuel pressure. The fuel pressure needs to stay above 45psi at all times and is typically set around 52 psi from the factory. Well the factory fuel pressure regulator spring is weak and looses it's tension over time and can't maintain adequate fuel pressure. There is an updated rebuild kit that uses a better, stronger spring. Installing this spring will bring your fuel pressure up to about 62 psi and solve that. Get a fuel pressure gauge. It's important.
So that covers the frequent complaints with the 6.0. They are all well known at this point as are the solutions. Does it suck we have to fix Ford's blunders? Heck yes it does. But again we know how and once done you will have a very reliable robust truck that is well worth the effort. So address the issues as you can and enjoy your truck. It is a dynamite vehicle. I love mine.
__________________
Old 08-19-2011, 07:54 PM
Thanks guys! Are there bolt on systems, do you just weld 4 inch pipe, or do you even run pipe? Can ask what you mean by "with the cat cut off you will be fine as long as you don't tow"? I do pull a trailer now and then. Not every week but occasionally.
Old 08-19-2011, 07:59 PM
these are all bolt on parts....
if you need any prices or have any other questions dont hesitate to PM me
-Raul
Old 08-19-2011, 09:32 PM
Feedback Score: 3 reviews
The cat restricts alot of exhaust noise, which means when you remove it, it's gonna have more rumble. Some members don't like a loud exhaust.
Old 08-20-2011, 09:27 AM
Thanks Raul. I'll be getting in touch with you for sure!
Gotcha. My wife actually likes it loud. She wants it louder. So I'm in luck that I've got a lil redneck girl for a wife! The exhaust on my other trucks helps to put my daughters to sleep. She's also after me for wheels and bigger tires.
