Walbro 255 Fuel Pump - Ford Powerstroke Diesel Forum
Old 08-15-2011, 07:55 AM
Are the walbro units a direct bolt-in to the stock basket? I have one sitting in my garage and I want to put it in my truck just so I don't have to worry about pressure loss issues.
Old 08-19-2011, 06:26 PM
There is not a fuel pump in the tank of your truck, it is mounted to the frame rail under the driver side seat.
Old 08-20-2011, 03:59 AM
first get a fuel pressure to monitor you pressure,at idle and driving.if pressure is below45psi when driving get the Ford blue spring increases the pressure to 68-70 psi.
here is a link on the spring mod:
Fuel Regulator Upgrade w/ Pictures - Diesel Forum - TheDieselStop.com
ford spring without housing 6E7Z-9C165-B or international number-1854267C94
Old 08-24-2011, 02:48 PM
I already have the fuel spring mod done. I just want to know if a walbro 255 is a direct "slip in" unit.
