Those with SRL+ (6.0) - Ford Powerstroke Diesel Forum
Old 08-10-2011, 08:20 PM
'Merica
How many PSI of Boost do you run? I think i've got a leak.
Old 08-11-2011, 04:23 AM
I typically will see 25-26..every once in a while it'll spike to about 30
Old 08-11-2011, 05:11 AM
On SRL I have seen up to 28 on my edge cs, normally 25-27lbs
Old 08-11-2011, 05:54 AM
Iv seen up to 39 on my srl+ normally around 30-35
Old 08-11-2011, 06:10 AM
Should be around 30... SRL on an 04 w/powermax it pretty much holds 28-30 until you wanna let off..
Old 08-11-2011, 06:24 AM
Feedback Score: 3 reviews
On my truck, after TC lock up, roll into WOT.
SRL 26-27psi
SRL+ 28-29psi
SRL++ 32-33psi
Old 08-11-2011, 07:16 AM
Suck, Squish, Bang, Blow!
Looks like Josh has more boost than you! LOL
Old 08-11-2011, 03:57 PM
IU Hoosier Fan
It depends how you drive it....
I can make my SRL get 30+ psi with no problem if I want too
Old 08-12-2011, 11:33 AM
I hit 35-36 psi with my regular SRL depending on how I drive and really roll on it from about 55-90. It was pretty easy hitting it also. Got a little sceerd** so I let off.
Old 08-12-2011, 08:25 PM
'Merica
Thanks guys. im only gettin ~ 25psi. or so. figured it was higher than what i was gettin. On the hunt for boost leaks tommorow!
