Howdy,
I just purchased a 05 Excursion with the 6.0 and am new to this motor. I have been doing a lot of reading here and other forums trying to get up to speed so that I can get everything done that needs to be done. The truck is an 05 with 41,000 miles. The short block was replaced by Ford warranty at 20,000 miles. I bought the vehicle on line (E-Bay) flew out to California and drove it about 2,000 miles home. It seemed to run great and had no issues on the way home. I am wanting to make the engine reliable and long lasting, along with some extra power and mileage. I have an appointment to take it to River City Diesel on September 12th and get the following done; ARP headstuds, Black Onyx head gaskets, Change to Cat ELC coolant, Clean, Magnaflux and Resurface Heads, Complete EGR delete, New Oil Cooler, ITP fuel system, SCT X3 tuner with river city custom tunes, Magnaflow 4" Stainless Turbo back Exhaust, AFE cold air intake, 3 gauge a-pillar pod, Autometer Ultra-Lite II Boost Gauge, Pyrometer and Fuel Pressure Gauge. I have tried to do my homework and cover the weakspots in the engine, if their is anything I should be considering that you guys do not see on my list, could you let me know? I will be posting this on a couple forums to try to get as many opinions as possible, Thanks for the help! Brad |
Scratch the "black onyx" head gaskets off your list and go with FORD factory gaskets. The gaskets were never the issue, the head bolts are. The "BO" gaskets are also failing at a MUCH higher rate than the stock ones are. Cool name, so-so product.
Dummy plugs and the standpipes in the oil rail should be replaced if not already and also stc fitting for the HPOP.
Dummy plugs and standpipes would be addressed as part of the head gasket/stud job.
The STC fitting should DEFINITELY be replaced, BUT, he has an 05 Excursion. This would mean an 04 engine and the 04 does not have the STC fitting. To the OP: check the sticker on the passenger side valve cover. If it is an 05 engine, put that STC fitting on your list! (I believe it will be an 04 engine, since the EX was used to "use up" the remaining engines from the previous year). |
i have heard this a couple of times so i checked my X. It's a january 05 with an 05 sticker on the motor.
Bypass filtration for the oil is always a good thing and a coolant filtration system. If you are going to spend that kind of money why not? These two things will defiantly increase the life of your motor. Also good synthetic oil and make sure your always getting good quality fuel. I like Chevron here in FL.
They did say that they would do the STC fittings also. As far as the head gaskets, will change to the stock Ford head gaskets. I asked about the coolant filtration and they said not necessary since I would no longer have the EGR or EGR cooler and would be all flushed out as part of switch to ELC. I am still considering the bypass oil filter, but am actually already spending more than I had budgeted, so that may have to come down the road. Thanks for the suggestions! I have more planned down the road anyway, knowing me and my love for power, it may end up with injectors and a bigger turbo down the road, but for now I am just trying to get a good start.
As far as fuel, everything around me seems to be 20% bio. I will definetly run synthetic oil.
magnaflow is very expensive system. there are many other cheaper systems with out hte sacrifice of quality. mbrp, silverline, I have delete pipes for 20,000 miles with out issue for quality. Im very happy that I got the delete pipes.
no need for black onyx head gaskets, get oem head gaskets. Dont get the itp fuel system, get the ford update fuel reg kit), |
I'd go either MBRP or Diamond eye on the exhaust rather than magnaflow-great car exhaust, but IMO, both MBRP and Diamond eye are more bang for your buck. Stainless if at all possible. I'd also consider either an edge insight, scangauge, or a 3 gauge pod. IMO, the insight is the best option as it is expandable and offers more options.
Another thing, make sure to do the updated fuel pressure regulator (blue spring) while you're in there! |
