58v FICM - Ford Powerstroke Diesel Forum
post #1 of 25 Old 07-23-2011, 01:22 PM Thread Starter
capcalvin's Avatar
58v FICM
Looking at the 58v ficm from swamps or innovative. My stock ficm is starting to read a little low (46-47.5 briefly hits 48 every now and then) Just want to replace it before it takes a crap on me. Just looking for some input on this. Swamps is $825-$350 core=$475 Innovatives is $790-$170 core=$620. Swamps is $145 cheaper than innovatives. If I'm doing my math correctly. So right now Swamps is #1 choice. Has anyone experienced any problems running the 58v? What are the pros/cons of this unit. Thanks in advance for any input. Thanks!
'03 F350 6.0 CC dually lariat 4x4
Autometer gauges:
Pyro, boost, fuel pressure
Edge insight cts
Bulletproof EGR cooler (Blocked off)
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Exhaust: MBRP 4" cat back with delete pipe
SCTx3 Tunes by Innovative and Gearhead
Swamps 58v FICM
High idle mod
SRW front wheel conversion
ARP head studs
capcalvin is offline
post #2 of 25 Old 07-23-2011, 01:54 PM
taskforcefreddy's Avatar
Anything above 45 volts is still considered to be within specs. Hell, my 58 volt FICM from Swamps still registers 46-47 and RARELY hits 48 volts. What is the voltage upon startup when it's cold? If it's dipping into the 30's, then you might want to consider replacing it. Until then, save your money.
taskforcefreddy is offline
post #3 of 25 Old 07-23-2011, 02:14 PM Thread Starter
capcalvin's Avatar
Maybe your right. It reads 47-47.5 when first started in the morning. Of course lately its been in the 90's in the morning so I'll just have to wait till fall/winter to get a true cold reading. Unless I take it out and put it in the fridge overnight. Maybe I'll take your advise and wait and see. I've been having some drivability issues lately. But I think its just my injectors being picky. If I don't run fuel additive of some sort, my engine developes a rolling idle and has no low end power. If I juice it up with diesel kleen or stanadyne performance, it smoothes right out and runs like a champ. Thought maybe higher ficm voltage might help with this.
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
post #4 of 25 Old 07-23-2011, 02:34 PM
When mine was going, it was registering sub 35 volts even when it was 75 degrees out upon first startup of the day. Do you have any white smoke that comes around randomly? I had a couple bad injectors and she would billow white smoke while idling. How are your fuel filters? Perhaps they need to be changed which is why you're getting the performance issues. Whatever the case, upgrading your FICM to the tune of $500 prolly isn't gonna resolve your problems man.
post #5 of 25 Old 07-23-2011, 03:43 PM Thread Starter
capcalvin's Avatar
No white smoke from what I can tell. Fuel filters get changed religiously. Fuel pressure is 65 psi and never drops below 60 at WOT. Its running good now. Think I'll just wait it out like you said. I'm obsessed with this truck to the point of insanity! Of course Its the only thing I have to spend my money on, so it gets treated pretty good. Thanks for the reality check and your input.
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
post #6 of 25 Old 07-23-2011, 03:47 PM
bwillis2003's Avatar
Mine starts at like 42.5 volts and within a minute its at 48v, from what ive heard, even if its cold, if it hits below 46v, it's bad.. ofcourse if it's in the 30s it's really bad.
Not tryin to jack the thread, just adding some info about what ive heard/subscribing lol
Brandon
2007 F-250 6 point oh
146,000 miles
2.5 inch BDS leveling kit
35" Toyo Open Country A/T
OEM rotors w/ Hawk LTS pads
5 inch custom sidepipe
Edge Insight CTS
SCT X3 w/ Innovative Tunes
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
FICM fixed by Ed/tuned by PHP
S&B Intake
Dfuser Coolant Filter Kit
2003 F-250 7.3
84,000 miles
SOLD
bwillis2003 is offline
post #7 of 25 Old 07-23-2011, 03:57 PM
Hey,I live in Valpo also.. Who did you have do your egr delete and head studs? I may be doing a egr delete soon.. I have my trk back end jacked up right now so in the morning I will have a look under the valve and see whats up.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #8 of 25 Old 07-23-2011, 04:00 PM
^ Yours is most likely showing indications of being on its way out.
post #9 of 25 Old 07-23-2011, 04:07 PM
If youre talking to me, ya thats what I figured. I feel like I have like no power too. Although, I am just running off the downpipe right now
Brandon
146,000 miles
Edge Insight CTS
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
S&B Intake
2003 F-250 7.3
84,000 miles
SOLD
post #10 of 25 Old 07-23-2011, 04:13 PM Thread Starter
capcalvin's Avatar
Actually I did the EGR block off myself. The HG's and studs were done by Magiera Diesel Injection in Crown Point. They are the only ones I trust to work on my truck. They are a dealer for Bullet proof if you want to keep the cooler and just get the upgraded one. By the way, theres a G2G happening Aug. 7th in westville. Heres the link to the thread. NWI G2G
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
