05 ford f250 performance - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 05-29-2011, 08:34 PM Thread Starter
hey everyone i have a 05 f250 6.0 diesel an im lookin on doing some upgrades on her. here in about 2 weeks it will have a 4 in exhaust from turbo back an soon i will be adding a afe full intake an a egr bypass on it an i keep reading on the 05s throw a code when you do a egr bypass an was askin what would be the best chip/programer to run on that truck that will also cancel out that thrown code? head studs an head gasket are soon as well... any help would be awesome thanks
forddurr is offline
post #2 of 16 Old 05-29-2011, 11:11 PM
To start with the stock air intake on the 6.0 is about as good as they come good to 500HP and the best preogrammer to get is the SCT X3 from Matt at Gearhead or Innonation Diesel have them write the tunes you want the best way to go and it should clear the code, but i would get a good set of gauges something like the Edge Insight CTS to check temp spread on ECT-EOT max 15* a coolant filter to remove the casting sand and a fuel pressure gauge because under 45lbs at WOT may kill injectors, this is a start.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 16 Old 05-30-2011, 04:31 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
IMO, gauges/monitor should be the first thing to do. You'll need a way to monitor the motor to look for any issues the truck may have (EOT-ECT delta, fuel psi,weak FICM, ect) before you spend all your money on performance parts. Make the truck reliable first, the '05s have there own set of issues that need to be addressed (STC fitting, dummy plugs, ect).
midnite rider likes this.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 16 Old 05-30-2011, 09:30 AM Thread Starter
the edge inside cts will that have all the gauges on it that i need to check everything?
forddurr is offline
post #5 of 16 Old 05-30-2011, 01:35 PM
Yes-About the only gauge you will have to get is a fuel pressure gauge the CTS will do fuel pressure now but the cost of doing it is high. I have the Autometer elc. 0-100 on a column mount with the hose adapter works great.
This is what i got for the fuel pressure gauge, it goes into the test port, this is a cool set up gets the sender away from the heat and viberation of the motor.
6.0L Fuel Pressure Adapter
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #6 of 16 Old 05-12-2015, 03:01 PM
I'm looking to upgrade my 05 6.0 f250, need help with what to get and what not ? What should I start with!?
Westfall61 is offline
post #7 of 16 Old 05-12-2015, 03:24 PM
Jason99's Avatar
You should start with a monitor of some kind to make sure your engine is healthy and you can keep an eye on things.
Make sure you are keeping up on maintenance as well. A good 5W-40 synthetic motor oil, Mobil 1, Delo, Rotella and OEM oil filters only. All other fluids as well.
You can go with an SCT Livewire for monitoring first and then add tuning to the truck later, custom tunes are best. I would start with an exhaust upgrade first however before tuning, 4" or 5". And a coolant filter is a good investment IMHO.
Others will chime in and have more.
2005 F-250 Lariat FX4
Sinister Coolant Filter
4" Catback Exhaust/No Muffler
Blue Spring Update
Edge CTS Monitor
X4 with WPE White Noise Tune
6.0 Hard Starts and No Starts? Check out DTR
Originally posted by Heavy_GD
#DTR4Life
Jason99 is offline
post #8 of 16 Old 05-12-2015, 06:46 PM
midnite rider's Avatar
Quoted: 285 Post(s)
exactly what he said.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #9 of 16 Old 05-24-2015, 12:58 PM
Just bought an 05 f250 as well and had the egr valve cease open and give the cars behind me a smoke screen. Had it cleaned out to buy time but also noticing a bit of oil leaking from who knows where. I plan on egr delete and oil cooler, oil bypass filter and coolant filter and exhaust in that order. Should I rearrange these plans even with the egr already becoming problematic? I would rather get the tuner and gauges later after I make the known issues extinct...
glloy is offline
post #10 of 16 Old 05-24-2015, 01:04 PM
ZMANN's Avatar
Quoted: 1353 Post(s)
I would do the tuner first it will shut off the valve and code
you could even tack the valve shut
gauges (monitor) second this will let you see what else you may want to do when doing the delete
then focus on your EGR delete
based on this and your other post thats what I would do to avoid doing the manifold removal twice or just figure an oil cooler and flush when doing the EGR if you are set on getting a monitor later
the AFE and exhaust are not necessary you won't e gain anything but decibels IMO
We Miss you Ronnie
ZMANN is offline
