6.0L rebuild: injector choice question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-12-2011, 12:08 PM Thread Starter
This is my first diesel rig, and it's a 2003 F350 CCLB Dually 4x4. The motor in it supposedly needs injectors, but I'm going to buy a core motor and rebuild it just in case the one in the truck is shot. Here are the things I'm looking to do:
1. EGR delete
2. rebuilt oil cooler
3. Victor Reinz head gaskets
4. 4c3z-6r007-a rebuild kit
5. ARP head studs
6. rebuild HPOP (possibly Adrenaline?)
7. 6.4 banjo bolts
8. blue fuel pressure spring
9. bully dog 4" exhaust kit
10. SCT Tuner (not sure which one yet, but will include gauges)
11. Rebuilt Injectors
Now here is the main question I have: should I go with BD Injectors (stock), as I can get them at a discount through my company; or should I look to a different brand of upgraded injectors (I've seen the term stage 1 thrown around a lot).
For right now, the turbo will be the stock unit. I will use the truck for some daily driving, hauling some motors back and forth, and playing. I will not be doing any type of racing, pulling, etc. I may tow from time to time (would be a car on a flat trailer), but that is about it. Since I'm building the motor, I'd like to do it once and do it right. What injectors would you recommend, and why? Also, any other upgrades to the motor that I may have missed?
The transmission / etc. will be worked on / upgraded down the line, including the converter, so I'll save that stuff for another thread.
billyrb is offline
post #2 of 9 Old 04-12-2011, 03:36 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
For your stated goal put stock injectors back in it.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 9 Old 04-12-2011, 05:36 PM Thread Starter
how much power will the stock BD injectors support?
billyrb is offline
post #4 of 9 Old 04-12-2011, 05:41 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I dynoed right at 400 at the wheels with stock injectors.
dhanna6powerstroke is offline
post #5 of 9 Old 04-13-2011, 05:08 AM
Chapter Director
cubalz's Avatar
Why on earth would you replace a motor that only needs injectors?
2004 F350 6.0L Power Stroke Diesel
4.5" Lift
37 x 13.50 x 16 Pro Comp Extreme AT Tires
Mickey Thompson Classic II Rims
Power Tow Mirrors
Ranch Hand Front Bumper
Bully Dog RFI Intake
Bully Dog Outlook/Triple Dog Power Pup
ARP Studs
Blocked Off EGR Cooler
5" Exhaust Tip
Low Profile Toolbox
Prodigy P2 Brake Controller
Kenwood In Dash DVD Double Din Radio
HFCM Water Separator Drain Plug
Dieselsite Coolant Filter Kit
cubalz is offline
post #6 of 9 Old 04-13-2011, 05:17 AM Thread Starter
I'm not replacing the one that is in the truck yet. It has around 215k miles, and I haven't had the chance to turn it over yet (both batteries were dead), and seller said he 'thinks' it needs injectors; claimed that it started running sluggish, then as he tried to back it into his driveway, said it lost almost all power, at which point he shut it down and started driving his other truck.
I'm installing new batteries this weekend and have an OBDII code reader and will see what it says and will try turning it over. But, since I have access to core motors, I figure that I'll go ahead and build a replacement motor so that one day I can swap them. That is assuming the motor that is currently in the truck runs for a while, then I can swap when it starts going south. But, if the motor in the truck now is junk, then at least I'll have another motor ready to go.
billyrb is offline
post #7 of 9 Old 04-13-2011, 07:36 AM
PGreenSVT's Avatar
Try turning it over by hand first. You don't want to bend anything if it is hydrolocked.
RIP Mitch
the Org crew
post #8 of 9 Old 04-13-2011, 08:12 AM
Snake's Avatar
Quoted: 46 Post(s)
+1
Snake is offline
post #9 of 9 Old 04-13-2011, 08:30 AM
Powerstroke Techie
Lilpooh's Avatar
I'm not replacing the one that is in the truck yet. It has around 215k miles, and I haven't had the chance to turn it over yet (both batteries were dead), and seller said he 'thinks' it needs injectors; claimed that it started running sluggish, then as he tried to back it into his driveway, said it lost almost all power, at which point he shut it down and started driving his other truck. go.
This might be as simple as the IC boot ripped or HPOP system issue.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
