Extended crank times??? - Ford Powerstroke Diesel Forum
Old 03-27-2011, 12:49 PM
I am having some issues starting my truck. It seems to take longer and longer to start up. When it is cold or mildly warm I can expect 5-6 second crank times. Sometimes having to stop turn off the ignition and start all over. Not sure where to start looking. Any ideas??
Old 03-30-2011, 07:37 AM
Another 6Slow
i would say try the dummy plugs in the front of the oil rail the o-rings are know to blow out, mine did and it would take a long time to start like that, ford has an updated dummy plug that fixes the issue, if thats not it could be a stand pipe or the STC fitting id start with the dummy plugs though easiest to check.
Old 03-30-2011, 12:04 PM
If it is a cold start issue check your FICM voltage with the truck running and cranking. It should not drop below 46v. If it does your FICM is toast. Send it to Swamps and get it rebuilt and upgraded to 58v. You can do that cheaper than buying a regular rebuilt FICM from Ford.
HPO related start problems are typically worse once the engine warms up and the oil becomes thinner.
Old 03-30-2011, 12:34 PM
information regurgitator
Its a rare occurrence when there is an error in a PGreenSVT post....
You do not check the FICM voltage with the truck running.
COLD KOEO and cold cranking.
Straight off Swamps website:
***FICM voltage tests should be performed with the engine oil COLD (ie, close to ambient air temperature). This will force the FICM into it's inductive heating strategy, which will give you a worse case scenario/voltage reading. If the engine has been run (within 5-6 hours of this test), then the warm engine oil may not give you an accurate FICM voltage.
On all 2003-2007 Ford 6.0L Power Stroke diesel engines you will find the FICM bolted to the drivers side valve cover...you may need to unbolt the coolant reservoir from the 'cowl' so that you can get your arms/hands back there to work on the FICM.
You don't need to drain the coolant...just unbolt the bracket that hold the coolant reservoir, and gently move it as far out of your way as possible. Be careful, as there is a plastic coolant connector that can be cracked if the coolant jug is handled forcefully.
On the top of the FICM, you will see a diamond/oval shaped metal plate...remove the two screws from that plate (Torx#20).
under that plate you will either see 7 "lugs"...or 4 "lugs" (depending on the year of the truck)...
if you have a "7 lug FICM"...you want to put one lead from your multimeter onto the upper left "lug"...and the other multimeter probe to ground (bare spot on the cylinder head, alternator bracket, negative battery terminal, etc).
If you have a "4 lug FICM"...you will want to check the lug on the right (closest to the drivers side fender).
be careful NOT to lean the probe on the FICM lug...over onto the aluminum case...you might let the smoke out, LOL...
Have someone turn the key to the 'on' position (don't crank it yet)...and see what your FICM voltage is. It should be >46volts.
Next have someone crank the engine...and see what the FICM voltage is while cranking...again..should be >46volts.
Go ahead and start the engine...and see what the voltage is while idling.
If the FICM voltage drops below 46 volts...then it is "bad"...
we have seen FICM's as low as 17volts...some 19v's...some in the twenty's and low thirties...
obviously...the lower the voltage...the 'worse' the FICM is...and the more likely that (cold) rough running would be a result of a bad FICM.
however..if you email (or call) us and say that your FICM is dropping to 43-44volts...while low..I think that you may have some underlying injector issues that may be contributing to your cold rough running, as much as the slightly low voltage FICM
You can email any questions to dave@swampsdiesel.com ; however, if your voltage IS low...then your FICM is bad, and you can place an order at the following link. Swamp's Webstore - Custom Electronics
due to the high demand of our (48v &/or 58v) Heavy Duty FICM's, we are typically running 2 days behind on current orders...if you need express delivery, please make a note in the comments section during your online checkout, and we will call you with shipping options and rate quotes.
Old 03-30-2011, 01:26 PM
I usually eliminate the KOEO test because I have not found the results to be reliable. If the FICM is bad it will show up during the Cranking and Running tests. My own FICM would read 48v with the KOEO test but the others failed miserably.
Nice write up.
