New Stack
Well, I was bored and picked up a stack off ebay. Its a 5 inch turnout, I removed my 5 inch over axle rear section w/6 inch tip to put this on. I can always change back if it gets annoying or I get bored again.
New Tires come this week ![]() ![]()
Looks good! Is it loud inside the cab?
Its louder yes, but its not crazy. To be honest I finished it two fridays ago and havent driven it since since I was in Michigan the past week. Ill get some road time this week and keep you all updated
Looks good man!
Sent from phone, can't see sigs.. |
Thanks man, I just made a 2 hour trek, Its definitely louder in cab on the highway than my factory exit exhaust. Its honestly not bad if you travel at 65mph (which is the fastest i usually go unless im driving to Michigan then maybe i'd hit 70 for a while)
It could get annoying for someone fast, I just happen to love my trucks loud
Can you post a link where you got it from? Thanks
Yea I want to have a set up like this with a CAT pipe. How did you split up your other exhaust when you removed it. Or did it slide right out?
I got the stack from ebay user jervoll709
My exhaust just comes apart once the clamps are removed. I removed my muffler delete pipe and over axle rear section. Then i used flex pipe at a 45* angle, used a 45* bend i had and another short piece of flex pipe right into the stack. It was pretty simple, its actually pretty ghetto right now but that will be fixed when I have more time (Ill be buying an actually stack clamp, band clamps, and a 90* bend to make things a lot easier and cleaner) |
Looks good, but I would have went with a miter... But that's just me. It's your truck
What kind of tires are you getting
