How much performance gain do you really get with a Air Dog or FASS....
i am trying to see if its worth getting... I just have the mods listed below but want more milage i only get 21 on the highway... but wanna try for more... i just wanted to know if it really helped out the spray pattern for the injector and all that jazz and just get you guys input...
Won't help that any. It's just to keep your injectors happy.
i got 26 highway on mine but i had the banks economind 6 posistion chip on it . wat the did was it limited how much fuel was being deliievered when i was steady drivin the same speed at the same rpm
I didn't see any gains or losses. I do have the piece of mind now that if I want to go with bigger injectors and a larger turbo my fuel delivery system will handle it. Oh, i got a cool AirDog sticker for my tool box also!
I did it for the piece of mind of extra filtration
I didn't see any mpg gain with my AD2 but it does start easier with it. Main reason I put it on was like previously stated, injector piece of mind. I have an '05 which is worked hard all the time and unlike guys I know that run an OEM fuel system I have only had to replace one injector in the life of my truck and that was due to me running super low on fuel.
ONLY GET 21!!!!!!! dude you should be super happy with that! nothing wrong there i wish i could touch that number ill be happy if i can get to 18mpg's. but to answer the question the only thing i saw improvement in was a little throttle responce
Same here. Throttle response improved. Slightly quieter, but not much. I can say whether I got better mpg because I bought it shortly after getting my tuner (fuel pressure was dropping drastically). Between tunes and airdog I gained about 1.5-2.0 mpg... which puts me at 16ish mpg down the hwy. Thanks for rubbing in your horrible mileage!!! lol. jk.
People claiming they get 21 or 26 are just using their dummy gauge in the cab. I bet if it is hand calculated it would be more on the 16-18 side. It just does not happen getting that type of MPG with our rigs.
My Excursion doing 110 kph on cruise control flat ground and no trailer gives me 20 - 21 mpg (imperial gallon) figured out by hand. If I take over it drops to 16 - 18. My engine isn't stock but it is close to it.
