What size injectors????????
I am purchasing injectors soon and i wanna get some hot rod injectors. My question is what size should i run???? I will be having ford install the solution kit that includes:
•EGR Delete Kit by Sinister Mfg. Company •Black Onyx Head Gaskets •Black Onyx Exhaust Gaskets •ARP Head Stud Set •Ford Factory Oil Cooler Kit •Ford Factory Oil Cooler Screen •Ford Factory Intake Gaskets •Ford Factory Turbo Hardware/O-Ring Kit After that i wanna get a sct tuner for it. I wanna get biggest ones i can with these modifications any suggestions????? Thanks Longmire34 |
How do you use your truck? tow?
Injector size
I will use the truck for towing prolly one or two pickups on a trailor and I would like to try sled pulling with it a little bit.
Since you to tow often it would be better to get a bigger turbo like the powermax turbo with tunes. You can use a high hp tune (120-140hp) with the bigger turbo and still keep your EGT's low. The powermax will also increase power over the stock turbo.
With bigger injectors and stock turbo you will be limited with power because the bigger injectors will increase the EGT's. With the turbo alone you will get a decrease in EGT's and increase in HP. Then if you get tunes for the turbo you can use what ever hp tune towing or not and still have good EGT temps. The price of the powermax turbo is ~$1,300, a set of injectors $2500-$3,500. Last edited by smokersteve; 03-21-2011 at 08:37 PM. |
Full force..Inj's..and custom tunes for your stock turbo..something is in the works..PM me!
Cary |
