How accurate is the new FICM update on CS and CTS? - Ford Powerstroke Diesel Forum
Old 03-21-2011, 10:06 AM
I just downloaded and installed the new updates from Edge for my CTS and was excited about the FICM add. But when I put my CTS back in and read my numbers I was a little concerned. At ignition I read 48.5V then at start and idle it dropped to between 39-41 at a cold start not warmed up. What should I be reading at idle and how accurate does anyone think this reading to be? THanks.
Old 03-22-2011, 04:43 AM
I got the update showing 48-49 at idle or running down the road. Maybe checking it the old fashion way is required.
Old 04-04-2011, 04:25 AM
mine is the same, on cold start ups.
key on no start it reads 47.5.
start and it drops to 39-40 but once warmed up it jumps back to 47. I think I might have a weak FICM on my hands. I think its pretty darn accurate.
Old 04-04-2011, 06:41 AM
Yup both you guys have bad FICMs.
Old 04-04-2011, 07:40 AM
awesome,
I emailed jonathan at swamps this morning, most likely will be ordering up the HD 48v from them with no tuning.
there goes the money I was going to spend on the sled
Old 04-04-2011, 11:02 AM
I'd spring for the tuning. It could be worth it depending on your current stragety.
Old 04-04-2011, 12:31 PM
I have one of the newer strategies. have to look on the insight for exact.
would this help bring my mileage back? I would love to get 20 again
Been debating rolling back my PCM/TCM also, not sure about that yet.
Old 04-05-2011, 09:31 AM
got a hold f swamps,
they told me to unhook the glow plug control module and see if it still drops. If it doesn't it is normal glow plug draw on the battery system. If it still drops then the FICM is shot.
Has anyone heard of this, really makes sense to me because I have no codes thrown and the truck starts fine.
i would really like to save 400 big ones if I can, my hat off the swamps for the help so far.
