Dash illumination wire - Ford Powerstroke Diesel Forum
Old 03-20-2011, 05:34 PM
Hey everyone,
I need a little help if possible and sorry ahead of time for the long post.
I installed a couple of gauges this weekend and I am having problems finding the dash illumination wire. The previous owner had some sort of gauge/monitor so there was already a few taps to use at the grey connector.
However, none of them vary when I move the dash lighting up or down. The instructions from Diesel Manor are great, but are for a 2003. The connector on my 2005 is different. It still has a solid yellow at the 2nd from the left on the top, but it is a constant 12v when ignition is on.
I have heard you can tap in behind the dimmer switch, but am hesitant to do so since there are already taps in place if I can just fine the right one. My problem is that none of them change when using the dimmer.
Any suggestions??
Old 03-20-2011, 05:52 PM
Let's go B's!!!!
Feedback Score: 5 reviews
Just pop out the headlight switch and use a test light to find the dimmer switch wire. I don't remember what color it is, but it should only take about 30 seconds to find it
Old 03-20-2011, 06:15 PM
Man do I feel stupid... I was looking at the wrong plug. The previous owner tied into the rectangle grey plug to the left in the picture, so I assumed that was the right plug.
Took all of 30 seconds once I found the blue wire with white stripe. Time to put down the tools!
