SCT contacts?
i keep seeing people dropping names with guys from SCT that do the tuning and im just wondering where to get in touch with them and how. im having an issue with my tuner acting like its defueling the truck under WOT and high rpms. Just cuts out. Filters were just changed. Pleats are straight and i have the blue spring but it only does it under the street tune and performance tunes. Any help would be very appreciated. Thanks in advance.
It may not be the tunes, if your HPOP has a small leak forming, it's preventing the injectors from getting all the psi needed to work fully. Don't know what year truck you have, but if your user name has 04 in it, I assume it's a 04. The early '04's have the ICP sensor behind the turbo which are prone to failure.
Are you running custom tunes? Whom ever you got your custom tunes from is who you should be calling. Eric is Innovative Diesel Vivian is Quick Tricks Automotive Matt is Gearhead Automotive Performance |
When you switched from the triple dog to SCT, did you have the truck reflashed? The bully dog stuff leaves a footprint that messes up the SCT programing. Read the last post of this thread.
Bullydog vs SCT |
yeah i had it reflashed with the latest strat when i took the BD off/before the SCT was put on.
