HELP! i have questions
Is the dieselsite.com coolant filter system the answer to the egr problems? I know that a egr delete is the was to go and I can't because of smog. There is also the bp egr cooler, does the cab need to come off to install the bp cooler? How much do you think I would get charged for the install? Thank you!
Diselsite, DFuser, and Sinister (MKMCustoms.com) all offer coolant filters that are practically the same. As far as being the answer, they will help but you should also do a full flush and replace the Ford Gold with a Cat EC-1 ELC. See this thread.
How much would it cost to get a bp egr installed?
Buy and install the coolant filter, then get gauges or a monitor. You need to know your temps. If your egr cooler is good why replace it? I've got 110k on mine.
