Cleaned EGR & Pulled Muffler - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-11-2011, 02:24 PM Thread Starter
scrdanis's Avatar
I recently bought MBRP 4" w/o the CAT. Didn't sound much different than being CATless with the OEM exhaust. I took the extra piece of pipe and a band clamp and removed the resonator. I now have a straight pipe and it sounds different now. While I was working the truck I pulled the EGR to check it out, glad I did. The upper portion was 3/4 of the way plugged with soot material, the lower half was pretty clear. I cleaned it up withcarb cleaner and back in she went. Runs nie and sounds BADASS. Not obnoxious but robust!
06 F350 PSD 4x4 Lariat CC
Edge Evolution
Sinister Coolant filter
Stock Intake filter
Blue Spring
Banjo Bolts
4" MBPR turbo back exhaust (off-road)
EGR delete
scrdanis is offline
post #2 of 5 Old 03-11-2011, 07:13 PM
smokersteve's Avatar
Quoted: 20 Post(s)
good to hear. I am sure the build up is not only on the egr valve but also in the intake. Cleaning that out would be a good project to do on the weekend.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #3 of 5 Old 03-12-2011, 06:06 AM Thread Starter
scrdanis's Avatar
Not sure how to go about that part but am willing to learn. I scrappedsome of the carbon from the EGR mount and vacuumed it out, didn't seem to be to bad in there. When I bought the truck I started using fule additve (Diesel Kleen) and actually looked like the build-up was erroding but is speculation only. Would be interested in cleaning the rest of the intake though.
Edge Evolution
Stock Intake filter
Blue Spring
Banjo Bolts
EGR delete
scrdanis is offline
post #4 of 5 Old 03-12-2011, 06:33 AM
Quoted: 20 Post(s)
Intake Manifold Cleaning - Ford Truck Enthusiasts Forums
http://www.ford-trucks.com/ford-manu...%20removal.pdf
could you clean your intake manifold this way?
FICM Testing Videos
post #5 of 5 Old 03-12-2011, 07:06 AM Thread Starter
scrdanis's Avatar
Thanks, SMOKER
Edge Evolution
Stock Intake filter
Blue Spring
Banjo Bolts
EGR delete
scrdanis is offline
