Master cylinder hose leaking - Ford Powerstroke Diesel Forum
Old 03-10-2011, 06:10 PM
Send a message via AIM to BLKF250
i have an 05 F250 6.0 and when you pop your hood and look at the master cylinder there a high pressure line thats connected to the master cylinder kinda back against the fire wall and runs down behind the drivers front wheel you can see it threw the wheel well on the right side of the shock the hose runs above the frame mines leaking were its machined pressed and i gotta replace it anyone know how much those run iam going tomorrow to pick it up. whats the best way of installing those as far as draining all the fluid out of the master cylinder or hurry up and swap lines as fast as you can with least amount of fluid coming out any help would be great thanks....i gotta bleed the brakes also to get all the air out correct?
