Gauge benchmarks - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-09-2011, 08:08 PM Thread Starter
TerraScaper's Avatar
Gauge benchmarks
I was wondering if someone had some medians that i could compare my gauge readings to so that I could "keep an eye on the gauges" on my Livewire. I've got the gauges and am running the performance canned tune on the livewire and everything seems to be in check, even when I run it hard, there are alot of PIMs that i have no clue about.
From what i read i should be keeping the EGTs to below 1250* sustained
EOT and EOC within 15* (mine are hovering around this difference sometimes and other times both at 178* sustained periods)
Voltage should be at 14V (sometimes my battery light goes on but my voltage is a steady 14v)
Fuel pressure should be 60 psi at idle and 45psi + at WOT (guage on the way)
Tranny is around 160*
What other info should I keep an eye on every now and then to make sure engine is in check?
Thanks, got some new tunes from Matt on the way and want to make sure I can enjoy them to the maxx.
2004 F350 ECSB Powermax, 4" turbo back with muffler, SCT Livewire w/ SRL, ARPs, EGR delete, Spring, Banjos, some other zoodads
TerraScaper is offline
post #2 of 3 Old 03-09-2011, 11:38 PM
If you are seeing 178* you have a problem, and the problem is a stuck open t/stat the ECT should read around 190-192* and the EOT around 194-196* with a max difference of 15*
Others about right
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 3 Old 03-10-2011, 04:20 AM Thread Starter
Thanks Stroker, I'll take a look at that. It has seen temps up to 190, but for brief periods of time. I thought my truck took a while to warm up. Thanks for checking out my numbers.
